Старый 27.05.2011, 11:40   #1
ideveloper is offline
ideveloper
Endpoint Action Policy does not exist / AxInternalBase object
Hi all.
I am trying to create an AIF Service which returns some emails from all companies we had in AX.
The Service is created automatically with the AIF Wizard from the Query.
With the enabled cross company option (AllowCrossCompany: True) i get the following error:
When I turn off this option (AllowCrossCompany:False) I get the result (for one company).
Does anybody know how can I solve this problem???
Thanks.
Regards
ideveloper
Последний раз редактировалось ideveloper; 27.05.2011 в 12:18.
Старый 27.05.2011, 12:29   #2
ideveloper
Hi.
After I refreshed the services, removed and added the action in the Endpoint the problem (Action Policy doesnt exist) is gone.
Now I have a new one, which not appears when I turn off the cross company option!!!:
AifRequestProcessor-processServiceRequest
AifRequestProcessor-executeServiceOperation
Error executing code: AxInternalBase object not initialized.
(S)\Classes\AxInternalBase\setCurrentRecordFromExternal
(S)\Classes\AxdBaseRead\serializeRecord - line 23
(S)\Classes\AxdBaseRead\serializeRecord - line 68
(S)\Classes\AxdBaseRead\serializeQuery - line 32
(S)\Classes\AxdBaseRead\serializeDocument - line 39
(S)\Classes\AxdBaseRead\findDocumentList - line 14
(S)\Classes\AxdBase\findList - line 65
(S)\Classes\AifDocumentService\findList - line 38
(S)\Classes\MyService\find - line 4
(S)\Classes\DictClass\callObject
(S)\Classes\AifDispatcher\callServiceMethod - line 60
(S)\Classes\AifDispatcher\dispatchOperation - line 11
(S)\Classes\AifRequestProcessor\executeServiceOperation - line 20
(S)\Classes\AifRequestProcessor\processServiceRequest - line 101
(S)\Classes\AifRequestProcessor\processServiceMessageXml - line 58
(C)\Classes\AifGatewayAdapterReceiveManager\processRequest - line 7
(C)\Classes\AifBizTalkReceiveAdapter\processRequest - line 18
Regards
ideveloper
Старый 27.05.2011, 16:09   #3
Morpheus is offline
Morpheus
Аватар для Morpheus
602 / 167 (7) ++++++
Have you tried to compile forward the AxInternalBase class?
Cheers!
Старый 27.05.2011, 16:47   #4
ideveloper
Hi.
Yes. The compilation run through without any problems.
Старый 06.06.2011, 14:22   #5
ideveloper
Не может же быть, что здесь никого нет, кто нигода не имплементировал CrossCompanyQuery в АХ для BizTalk?
Мне очень срочно нужно решение этой проблемы.
aif, crosscompany, policy, query
Error 1075: The dependency service does not exist or has been marked for deletion Blog bot DAX Blogs 1 24.10.2011 14:26
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
Метод "SendMail" в COM-объекте класса "Dundas.mailer" возвратил код ошибки 0x80004005 (E_FAIL), который означает: The RCPT command failed. The specified account does not exist. Андрей К. DAX: Программирование 3 10.07.2009 16:08
Помогите лоху! "The user <user> does not exist. Please re-enter a valid user name." Сергей Аксенов DAX: Администрирование 1 02.03.2004 15:56
Проблемы: Удаление "Sales order" и ошибка 'Sales order, issue' does not exist. lm DAX: Функционал 0 16.01.2002 14:29
Часовой пояс GMT +3, время: 17:46.
