Старый 23.06.2009, 15:05   #1
SysDictCoder: Constructing date values
Источник: http://sysdictcoder.com/blog/constructing-date-values/
Sometimes you have to construct at date at runtime with part of the date based on user input. Like when you have to summarize transactions for a given year.
Ax has a built-in function for this but all too often I see people resorting to convoluted string conversions to achieve the goal. Please don’t, it’s harder to reade, more error prone and less efficient. Use mkDate() instead.
So instead of writing something like this:
static void Job1(Args _args){ int givenYear = 2009; // Value acquired somewhere outside the method date fromDate, toDate; ; fromDate = str2date("1/1/" + int2str(2009), 123); toDate = str2date("1/1/" + int2str(2009), 123);}
Write this:
static void Job1(Args _args){ int givenYear = 2009; // Value acquired somewhere outside the method date fromDate, toDate; ; fromDate = mkDate(1, 1, givenYear); toDate = mkDate(31, 12, givenYear);}
To me, the most important advantage of mkDate() is clarity. Using string conversions distracts from the actual task of constructing a date. Additionally because all arguments to mkDate() are integers it’s easy to do input validation or build a whole bunch of date values in a loop, e.g. every first of every month.
SysDictCoder: Detecting default values Blog bot DAX Blogs 0 21.05.2009 12:05
daxsol: Axapta Kernel Functions Blog bot DAX Blogs 1 16.05.2009 19:22
Dynamics AX: Today to Julian Date value inside Dynamics AX, X++ Blog bot DAX Blogs 0 07.03.2009 06:12
axaptapedia: Packing date range values in queries Blog bot DAX Blogs 1 09.11.2007 13:10
Часовой пояс GMT +3, время: 12:59.
