Старый 15.05.2009, 22:06   #1
daxsol: Axapta Kernel Functions
Источник: http://daxsol.blogspot.com/2009/04/a...functions.html
Math
real abs(real figure)
real sin(real arg)
real cos(real arg)
real tan(real arg)
real asin(real arg)
real acos(real arg)
real atan(real arg)
real sinH(real arg)
real cosH(real arg)
real tanH(real arg)
real exp10(real decimal)
real log10(real figure)
real exp(real arg)
real logN (real figure)
real power(real figure1, real figure2)
real frac(real decimal)
real trunc(real decimal)
real round(real figure1, real figure2)
real decRound(real figure, int decimals)
anytype max(anytype figure1, anytype figure2)
anytype min(anytype figure1, anytype figure2)
Financial
real ddb(real price, real scrap, real life, integer period)
real sln(real price, real scrap, real life)
real syd(real price, real scrap, real life, int period)
real dg(real sale, real purchase)
real idg(real purchase, real contratio)
real fv(real amount, real interest, real life)
real pv(real amount, real interest, real life)
real pmt(real principal, real interest, real life)
real pt(real amount, real percentage)
real rate(real future-value, real current-value, real terms)
real term(real amount, real interest, real futurevalue)
real cterm(real interest, real future value, real current value)
Conversion
str ansi2Ascii(str ansiString)
str ascii2Ansi(str asciiString)
int any2Int(anytype object)
real any2Real(anytype object)
str any2Str(anytype object)
enum any2Enum(anytype object)
date any2Date(anytype object)
int char2Num(str text, int position)
str num2Char(int figure)
real str2Num(str text)
str num2Str(real number, int characters, int decimals, int separator1, int separator2)
int date2Num(date date)
date num2Date(int days)
str int2Str(int integer)
int str2Int(str text)
str uint2Str(int integer)
str enum2Str(enum enum)
enum str2Enum(enum type,str text)
str date2Str(date date, int sequence, int day, int separator1, int month, int separator2, int year)
date str2Date(str text, int sequence)
str time2Str(int time, int separator1, int separator2)
int str2Time(str text)
Container
int conFind(container container, anytype element, ...)
int conLen(container container)
container conIns(container container, int start, anytype element, ...)
container conDel(container container, int start, int number)
container conPoke(container container, int start, anytype element,...)
anytype conPeek(container container, int number)
container conNull()
Date & Time
date mkDate(int day, int month, int year)
date today()
int timeNow()
date systemDateGet()
date systemDateSet(date date)
str dayName(int number)
str mthName(int month)
int dayOfWk(date date)
int dayOfMth(date date)
int dayOfYr(date date)
int wkOfYr(date date)
int mthOfYr(date date)
int year(date date)
date prevMth(date date)
date prevQtr(date date)
date prevYr(date date)
date nextMth(date date)
date nextQtr(date date)
date nextYr(date date)
int primoYr(date arg)
int ultimoYr(date arg)
date endMth(date date)
date maxDate()
Interval
int intvMax(date input-date,date ref-date,int func)
str intvName(date ref-date,int col,int func)
int intvNo(date input-date,date ref-date,int func)
date intvNorm(date input-date,date ref-date,int func)
Code Execution
str evalBuf(expression-string)
anytype runBuf(str job, ...)
String
str strFmt(str string, ...)
str strPrompt(str string, int len)
str strColSeq(str text)
str literalStr(int str)
str strIns(str text1, str text2, int position)
str strPoke(str text1, str text2, int position)
str strRep(str text, int number)
str strDel(str text, int position, int number)
str strKeep( str text1, str text2)
str strRem(str text1, str text2)
str strAlpha(str text)
str strLTrim(str text)
str strRTrim(str text)
str strUpr(str text)
str strLwr(str text)
str subStr(str text, int position, int number)
str strLine(str string, int count)
int strFind(str text, str characters, int position, int number)
int strNFind(str text, str characters, int position, int number)
int strScan(str text1, str text2, int position, int number)
int strLen(str text)
int strCmp(str text1, str text2)
int match(str pattern, str text)
Extended Data Type
int extendedTypeNum(str typeName)
str extendedTypeStr(str typeName)
Enum
int enumNum(enum enum)
str enumStr(enum enum)
int enumCnt(enum enumtype)
Table
int tableNum(table)
str tableStr(table)
str tablePname(table)
int fieldNum(table, field)
str fieldStr(table, field)
str fieldPname(table, field)
str tableId2Name(int table-id)
str tableId2Pname(int table-id)
int tableName2Id(str table-name)
str fieldId2Name(int tableid, int fieldid)
str fieldId2Pname(int tableid, int fieldid)
int fieldName2Id(int tableid, str fieldname)
str tableMethodStr(int table, int method)
str tableStaticMethodStr(int table, int method)
str tableCollectionStr(class tableCollection)
str tableFieldgroupStr(table, fieldGroup)
Index
int indexNum(table, index)
str indexStr(table, index)
str indexId2Name(int table-id, int index-id)
int indexName2Id(int table-id, str indexname)
Class
int classNum(Class)
str classStr(Class)
int classIdGet(object)
str methodStr(class class, int method)
str staticMethodStr(class class, int method)
Configuration Key
int configurationKeyNum(str keyName)
str configurationKeyStr(str keyName)
int securityKeyNum(str keyName)
str securityKeyStr(str KeyName)
int featureKeyNum(class featureKey)
str featureKeyStr(class featureKey)
int licenseCodeNum(str codeName)
str licenseCodeStr(str codeName)
Menu & Menu Item
str menuItemActionStr(class menuItem)
str menuItemDisplayStr(class menuItem)
str menuItemOutputStr(class menuItem)
str menuStr(class menu)
Various Object Info
str formStr(form)
str reportStr(report)
str queryStr(query)
str identifierStr(identifier x)
str resourceStr(str resourceName)
str helpApplStr(enum type, str id)
str helpDevStr(enum type, str id)
str curExt()
str curUserId()
int sessionId()
int dimOf(anytype element)
enum typeOf(anytype object)
int typeId(type)
str varStr(parm)
str funcName()
int prmIsDefault(anytype any)
Web
str webFormStr(str name)
str webReportStr(str name)
str webMenuStr(str name)
str webClientFileStr(str filename)
str webServerFileStr(str filename)
str htmlPdaHorizontalPageStr(str pageName)
str htmlPdaVerticalPageStr(str pageName)
str htmlStandardPageStr(str pageName)
Various
void beep()
int sleep(int integer)
int maxInt()
int minInt()
str getPrefix()
int setPrefix(str prefix)
int corrFlagGet(real arg)
real corrFlagSet(real real, int arg)
void refPrintAll(class object, str filename, str title)
За это сообщение автора поблагодарили: alex55 (1).
### Вакансии: программисты, консультанты AXAPTA (Москва, $1600-3100) Metetam Рынок труда Microsoft Dynamics 3 20.12.2006 17:00
Microsoft Axapta 3.0 Kernel Rollup 1 ??? (+) Lysov DAX: Администрирование 5 25.05.2006 13:11
AXAPTA 4.0 задерживается до весны 2006 (eng.) dmit2604 Microsoft и системы Microsoft Dynamics 61 12.03.2005 16:14
Часовой пояс GMT +3, время: 21:53.
