Solutions Monkey: Using AxContentPanel Control in EP
Источник: http://blogs.msdn.com/solutions/arch...rol-in-ep.aspx
============== AXContentPanel is derived from ASP.net UpdatePanel and enalbes sections of the web page refreshed instead of the entire page being refreshed with a postback and makes it more in. AxContentPanel builds on top of this and provides AX Specific constructs such as Passing Record Context and applying it to the underlying child controls. If you have a child user control that needs to display based on the context provided by the datasource in the parent user control or two independent datasources that do not have direct table level relation but one needs to change based on the context from the first datasource after executing some business logic, then AxContentPanel would come in handy. For example , if I have a page with Header and Detail Datasources separately and need to apply the context of the newly created header record in the top part of the page to the detail part of the page, then I would something like For example </SPAN> … … Header part of markup … … </SPAN> </SPAN> </SPAN> … … protected void Page_Init(object sender, EventArgs e) { IAxContext contextInterface = AxContextHelper.FindIAxContext(this); if (contextInterface != null) <SPAN style="FONT-FAMILY: 'Courier New'; FONT-SIZE: 10pt; mso-bidi-language: TA; mso-no-proof: yes"> contextInterface.CurrentContextChanged += new EventHandler(CurrentContextChanged); } protected void CurrentContextChanged(object sender, AxCurrentContextChangedEventArgs e) { if (e.CurrentContext != null) { this.AxContentPanel_ExpenseLine.ExternalContext = e.CurrentContext.RootTableContext; } } ============== Источник: http://blogs.msdn.com/solutions/arch...rol-in-ep.aspx
