#1 |
Solutions Monkey: How to use Chart Control in EP 2009?
Источник: http://blogs.msdn.com/solutions/arch...n-ep-2009.aspx
============== ASP.NET Chart Control (1) Install the components Chart Controls for .NET Framework Chart Controls Add-on for Visual Studio 2008 (2) MODIFY WEB.CONFIG Add the below as the child node to section </SPAN> Add the just after </SPAN> Add the just before (3) Create c:\TempImageFiles folder and give read access to the app pool Here is a sample markup for user control using Chart control ( replace the highlighted ones with your datasource control and the field or display field name) </SPAN> ============== Источник: http://blogs.msdn.com/solutions/arch...n-ep-2009.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
