Старый 10.05.2014, 06:30   #1
25,644 / 848 (80) +++++++
Kashperuk Ivan: Walkthrough: Fixing error "Incorrect Mobile device display settings..." on the mobile device when trying to sign in
Источник: http://kashperuk.blogspot.com/2014/0...incorrect.html
All the people who have tried the new Warehouse management mobile solution by now have probably hit the issue below and were confused about the error message displayed, as well as how to fix this.
The scenario is simple:
1. Install and Configure the Warehouse Mobile Device Portal through setup.exe.
As part of this step, you will need to specify a domain account to use as the identity of the IIS application pool that is used to run the Warehouse Mobile Device Portal (WMDP in short).
Warehouse Mobile Device Portal Installation Wizard
2. Completing the installation process will create a site in IIS. You can access this site, and it will open the WMDP home screen. If you now click on Log on to the mobile device, you will get the below error, if the domain account from the IIS app pool is not added as a user in Dynamics AX, or if he does not have sufficient privileges to run the mobile device portal.
WMDP error - insufficient privileges to connect to AX
3. After adding the user to AX and assigning the appropriate roles to him, you can try logging on to the mobile device again. Now, you might get a different error, like below
WMDP error - display settings are not configured
If you read the error message, you can see it complains about the mobile device display settings not being configured. Well, let's check them out, under Warehouse management > Setup > Mobile device > Work user mobile device display settings
As you can see on the below screenshot, I have them defined, and the setup is valid. Hmm, what is the above error about then?
Root cause:
The problem is actually with the default company set for the above AX user. By default the portal tries to connect to the company set as the default for that user, and thus cannot find the display settings, since they are created per company and don't exist in DAT (most probably).
4. After assigning a valid default company to the AX user, the domain account of which is running the IIS app pool for WMDP, we can try logging on to the mobile device portal again. Now we can see that we reach the Sign in screen, which means all is good in the world. :)
Warehouse Mobile Device Portal Sign In page
Hope that helps avoid initial confusion when trying to use the mobile device portal!
wmdp
Kashperuk Ivan: Workaround: After setting up a work-related Mobile Device menu item the user is constantly logged off when trying to use it on the device Blog bot DAX Blogs 0 10.05.2014 00:14
jodonnell: Reps Make Better Sales Calls Decisions with Mobile App for "CRM Call Planner" Blog bot Dynamics CRM: Blogs 0 12.04.2013 00:15
Gareth Tucker: Resco MobileCRM vs. CWR Mobile CRM – Microsoft CRM Mobile Showdown! Blog bot Dynamics CRM: Blogs 0 13.01.2012 17:11
Kashperuk Ivan: Running a class from AOT or "How to assign a class to an action menu item?" Blog bot DAX Blogs 0 22.10.2009 20:05
Часовой пояс GMT +3, время: 21:08.
