Старый 22.10.2009, 20:05   #1
Kashperuk Ivan: Running a class from AOT or "How to assign a class to an action menu item?"
Источник: http://kashperuk.blogspot.com/2009/1...to-assign.html
OK, so this might seem as a very simple question for many of you.
But, in reality, I still now and then meet people who have worked with AX for quite some time, but don't know this very basic concept.
Therefore, I just want to briefly describe it here to refresh everyone's memory
Apart from allowing to run the class from AOT, this will allow to assign it to a menu item (according to Best Practices, it should be a menu item of type Action), and run the class using this menu item.
Below is the correct syntax of the main method:
public static void main(Args _args)
//Your code here
Please also note, that there is an editor script that contains the template for the main method. You can invoke it from Scripts->template->method->main
Kashperuk Ivan: SysInfoAction class description - Improve your Infolog Blog bot DAX Blogs 0 17.09.2008 03:23
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Axapta Lessons: Menu Items Blog bot DAX Blogs 0 23.11.2006 16:00
Часовой пояс GMT +3, время: 02:49.
