Старый 20.01.2014, 19:11   #1
East Ocean - Technical: SQL Server 2008 Native Client cannot be found
Источник: http://eastoceantechnical.blogspot.c...cannot-be.html
Hit a weird issue while trying to install SQL server 2008 native client. I'm sure i have the correct installer and is extracted to local drive. Throw me resource unavailable 'sqlncli_x64.msi' not found.
Log file shows : "An installation package for the product Microsoft SQL Server 2008 Native Client cannot be found. Try the installation again using a valid copy of the installation package 'sqlncli_x64.msi'."
Endup is the issue with previous installation caused some incomplete setup on the client, go into control panel, find the SQL 2008 native client.
Unintall the existing client, then reinstall. Everything run successfully after that.
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
East Ocean - Technical: Migrating SQL Database to SQL Azure Blog bot Dynamics CRM: Blogs 0 29.02.2012 14:11
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Часовой пояс GMT +3, время: 22:11.
