Старый 13.07.2021, 05:27   #1
msdynamicsworld: How to apply non-working hours from a Calendar Template in Dynamics 365 Project Operations & PSA
Источник: https://msdynamicsworld.com/story/ho...operations-psa
Microsoft Dynamics 365 Project Operations and Project Service Automation (PO/PSA) users generally believe that non-working hours cannot be copied from one template resource to another resource when the Calendar template is assigned. They tend to assume that the working shifts and the weekends marked are the only ones that gets copied.
But that is not the case. There is a minor catch in how we do it. This article will help you set up a Calendar template with a resource that contains a template resource that has the non-working hours in the Work hours.
The solution
Perform the following steps to get to results explained above.
Step 1:
Add a non-working hour in the template of the resource by following the screenshots below. We will start by going to Settings and the Calendar Templates screen, which displays the Work template.
Step 2:
Click on the Template Resource and add a non-working hour as shown below in the screenshot.
msdynamicsworld: From the Microsoft Dynamics 365 Finance & Operations Blogs: Security references; Price override; Costing setup; Quality updates Blog bot DAX Blogs 0 12.06.2021 00:39
msdynamicsworld: How to create a milestone in Dynamics 365 Project Operations Blog bot DAX Blogs 0 06.05.2021 00:53
msdynamicsworld: Microsoft Dynamics 365 Project Operations: The road to "the new PSA" Blog bot DAX Blogs 0 20.02.2020 20:16
survivingcrm: What’s An “App” in Dynamics 365 Anyway? Blog bot Dynamics CRM: Blogs 0 06.01.2018 22:14
Часовой пояс GMT +3, время: 21:37.
