Старый 06.05.2021, 00:53   #1
msdynamicsworld: How to create a milestone in Dynamics 365 Project Operations
Источник: https://msdynamicsworld.com/story/ho...ect-operations
Users have always wanted a way to create a milestone in the project work breakdown structure (WBS) in Dynamics 365 Project Operations. Milestones allow us to mark a task by stating that it is a deliverable task. How can we achieve this functionality in Project Operations?
We  discovered that it is possible to mark a task as a milestone in the Project Operations (PO) WBS, which uses Project for the Web (P4W). In this article we will explain how you can start setting milestones in your projects.
Step 1
Open your PO environment and navigate to Projects -->Tasks Tab
Step 2
Add a task by and name. In this case I have added the task by the name “Milestone task 1”.
<h2>Step 3
msdynamicsworld: How to enable the new URS Board (Schedule Board) in Microsoft Dynamics 365 Project Operations Blog bot DAX Blogs 0 08.03.2021 19:11
msdynamicsworld: Dynamics 365 Project Service Automation quick tip: How to tie different types of contract lines to the same project Blog bot DAX Blogs 0 12.06.2020 18:14
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
Часовой пояс GMT +3, время: 16:51.
