Старый 21.10.2008, 20:05   #1
Solutions Monkey: EP Deployment - Internals
Источник: http://blogs.msdn.com/solutions/arch...internals.aspx
When you run Microsoft Dynamics Ax 2009 EP setup and go through the setup wizard, you might wonder what is going on behind the sceens. Here is a high level flow
Set BCProxyAccount Info in DynamicsAX ( from the user Account info entered for BC proxy in the Setup screen)
If(VirtualServerIsAlreadyExtended)
Get AppPoolAccount From IIS
if (ConfigureForWSS check box is checked in the setup screen)
If (ApppPoolAccount in IIS == BCProxyAccount in Ax)
Set password entered in setup screen for BC Proxy to the AppPool in IIS
else
ConfigureVirtualServerWithNewApplicationPool ( use the BC proxy account and password entered in setup screen for the
new app pool)
Configure AuthenticationMode to NTLM
else
If (appppoolaccount BCProxyAccount)
Log Error
else
Extend VirtualServer In Sharepoint
ConfigureAuthenticationMode to NTLM
Remove Old WebPart Package
deploy EP OnS harepoint
- deploy Static Files
- deploy Web Controls
- deploy All Web Parts
- add EP Site Definitions
- add/remove Site Templates
- install Feature - Ax Search Feature
- install Feature - EP Feature
- if(MOSS Installed)
install Feature - Ax EP MOSS Feature
- install Feature - Ax EP DataConnection Feature
- Create Install Information File
- Integrate EP Help
if (Reset IIS Option is checked)
Do IISReset
Upgrade Sites To DAX 2009 ( from DAX4.0)
Add Performance Counters
if (CreateWebSite Pption is checked)
Create EP Site ( if bcproxy account is same as app pool account and IIS reset is checked)
Solutions Monkey: Convergence session: Enterprise Portal Deployment Tips and tricks Blog bot DAX Blogs 0 26.03.2009 08:05
Solutions Monkey: Deploying Ax 2009 SP1 EP Blog bot DAX Blogs 0 05.02.2009 07:08
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 16:27.
