Solutions Monkey: EP Deployment - Internals
Источник: http://blogs.msdn.com/solutions/arch...internals.aspx
============== When you run Microsoft Dynamics Ax 2009 EP setup and go through the setup wizard, you might wonder what is going on behind the sceens. Here is a high level flow Set BCProxyAccount Info in DynamicsAX ( from the user Account info entered for BC proxy in the Setup screen) If(VirtualServerIsAlreadyExtended) { Get AppPoolAccount From IIS if (ConfigureForWSS check box is checked in the setup screen) { If (ApppPoolAccount in IIS == BCProxyAccount in Ax) { Set password entered in setup screen for BC Proxy to the AppPool in IIS } else { ConfigureVirtualServerWithNewApplicationPool ( use the BC proxy account and password entered in setup screen for the new app pool) } Configure AuthenticationMode to NTLM } else { If (appppoolaccount BCProxyAccount) Log Error } else { Extend VirtualServer In Sharepoint ConfigureAuthenticationMode to NTLM } Remove Old WebPart Package deploy EP OnS harepoint - deploy Static Files - deploy Web Controls - deploy All Web Parts - add EP Site Definitions - add/remove Site Templates - install Feature - Ax Search Feature - install Feature - EP Feature - if(MOSS Installed) install Feature - Ax EP MOSS Feature - install Feature - Ax EP DataConnection Feature - Create Install Information File - Integrate EP Help if (Reset IIS Option is checked) { Do IISReset } Upgrade Sites To DAX 2009 ( from DAX4.0) Create Install Information File Add Performance Counters if (CreateWebSite Pption is checked) Create EP Site ( if bcproxy account is same as app pool account and IIS reset is checked) ============== Источник: http://blogs.msdn.com/solutions/arch...internals.aspx
