Старый 27.01.2014, 16:28   #1
EVGL is offline
EVGL
4,445 / 3001 (0) ++++++++++
Effective "Date effectivness"
Дамы и господа, как вы считаете, можно ли запрограммировать следующий код в AX2012 лаконичнее:
public static void setStopped(
    InventItemOrderSetupMap     _inventItemOrderSetupMap,
    ItemStopped                 _stopped,
    date                        _effectiveDate = systemDateGet())
    InventItemSetupStopped  record;
    ttsBegin;
    record = InventItemSetupStopped::find(_inventItemOrderSetupMap.TableId, _inventItemOrderSetupMap.RecId, _effectiveDate);
    record.validTimeStateUpdateMode(ValidTimeStateUpdate::Correction);
    if (record && record.Stopped != _stopped)
        while select forUpdate validTimeState(_effectiveDate) record
            where record.InventItemSetupRecId   == _inventItemOrderSetupMap.RecId
               && record.InventItemSetupTableId == _inventItemOrderSetupMap.TableId
               && record.ValidTo                != _effectiveDate
            record.ValidTo = max(_effectiveDate-1, record.ValidFrom);
            if (record.validateWrite())
                record.update();
           && record.ValidTo                == _effectiveDate;
    record.initFromInventItemOrderSetupMap(_inventItemOrderSetupMap);
    record.ValidFrom = _effectiveDate;
    record.ValidTo = dateMax();
    record.Stopped = _stopped;
        record.write();
    ttsCommit;
ax2012
emeadaxsupport: "An exchange rate cannot be found for exchange rate type XXX between currencies YYY and ZZZ on exchange date." when you attempt to process in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 26.09.2012 07:15
dynamicscare: Updating Date Effective Tables in AX 2012 Blog bot DAX Blogs 0 01.05.2012 02:13
daxmusings: Valid Time State/Date Effective Framework - Part2 Blog bot DAX Blogs 6 07.10.2011 11:22
daxmusings: Valid Time State/Date Effective Framework - Part 1 Blog bot DAX Blogs 0 05.10.2011 14:11
daxsol: Axapta Kernel Functions Blog bot DAX Blogs 1 16.05.2009 19:22
Часовой пояс GMT +3, время: 16:50.
