Старый 11.07.2018, 22:11   #1
axmfg: Product Configuration: Multi-column dialog layout
Источник: https://blogs.msdn.microsoft.com/axm...dialog-layout/
In the spring release of 2018 for Microsoft Dynamics 365 for Finance & Operations, Multi-column layout is now available for the Product configurator's runtime dialog. To enable this functionality, select a model and open the Model properties form. In the Model properties form, there is now a new field Maximum number of columns. This field allows...
axmfg: Product Configuration: Setting values based on system variables - example, current user ID Blog bot DAX Blogs 0 29.04.2014 20:11
german_nav_developer: Dynamics NAV 2013 R2 multi-tenancy – Viele Mieterinnen ohne Stress und Neid Blog bot Dynamics CRM: Blogs 0 30.12.2013 19:00
axmfg: Understanding the default configuration concept for constraint-based products Blog bot DAX Blogs 0 17.07.2013 14:11
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
Часовой пояс GMT +3, время: 05:23.
