#1 |
axmfg: Understanding the default configuration concept for constraint-based products
Источник: http://blogs.msdn.com/b/axmfg/archiv...-products.aspx
============== Introduction The default configuration concept enables users to start the product configuration process when the main product master data are available within a legal entity. You can learn more of the details of this concept in this post. The default configuration concept You must use the configuration technology Constraint-based when you configure product masters and the product masters must be configured with only one active product dimension, the Configuration dimension. We refer to the products masters as constraint-based products throughout this post. To create a constraint-based product you must specify a valid product dimensions group which complies with this requirement. Figure 1 Error message when the wrong dimension group is selected You use the Configuration dimension to capture the final product configuration of a certain product model. The product model is represented in the system as a new product variant with a specific configuration dimension value. This is how Dynamics AX distinguishes between different results of the final product configuration. This allows you to complete a lot of tasks, such as:
Note - This is always the case for stocked products .For non-stocked products, you can specify a product category instead of defining the particular SKU. The default product configuration concept is dedicated to solve the above described issue. It enables end users to proceed with the product configuration as soon as the product has been released to the legal entity. Figure 2 The Default configuration is just there, after the product release When a constraint-based product is released to a legal entity, the system automatically creates and releases a default product variant with the configuration value Default. The Default parameter is derived from the Default configuration ID field on the Constraint-Based product configuration models tab in the Product information management parameters form. This form is located under Product information management > Setup. The Default configuration ID value is set automatically during system installation. It references the SYS Label @SYS331038, but you can always change the value. Figure 3 Product Parameters form The process to create and release the default product variant is completely transparent and once the Default configuration ID parameter is set, no further action is required. If the product is released to multiple legal entities, the same default product variant will automatically be released to all of those legal entities. Once the default product variant is released to the legal entity, the system will also update the default product variant fields on the released product. The default configuration dimension value is provided when you enter the item number on the order line. Any end user can change this setup in order to, for example, always have a basic configuration of a specific product suggested on all order lines Figure 4 The default product variant dimensions are set to match the Default Configuration ID Summary The default configuration concept makes it possible to start the product configuration process at the point where the main product master data are available within a given legal entity. In order words, it facilitates the first step in the overall process of configuring an order line and it goes without saying that the first step is a prerequisite to move on in the process. Thanks for reading. Источник: http://blogs.msdn.com/b/axmfg/archiv...-products.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
