Старый 05.12.2018, 15:11   #1
d365technext: Currency Conversion X++ AX7, D365FO and AX-2012
Источник: http://d365technext.blogspot.com/201...fo-and-ax.html
Convert currency to currency.
Static void main(Args args)
CurrencyExchangeHelper currencyExchangeHelper;
AmountMst amountMST;
CurrencyCode toCurrency = ‘AED’;
CurrencyCode FromCurrency = ‘USD’;
AmountCur amountCur = 5000;
currencyExchangeHelper = CurrencyExchangeHelper::newExchangeDate(Ledger::current(), systemDateGet());
amountMST = currencyExchangeHelper.calculateCurrencyToCurrency(toCurrency, fromCurrency,amountCur,true);
info(strFmt(“%1”, amountMST))
Convert Transaction currency to company ledger currency.
Method will convert the transaction currency in to accounting currency defined in ledger.
staticvoid Main(Args _args)
CurrencyCode transCurrency = ‘EUR’;
AmountCur amountCur = 5500.00;
amountMST = currencyExchangeHelper.calculateTransactionToAccounting(transCurrency, amountCur ,true);
info(strFmt(‘%1’,amountMST));
Convert Company currency to transaction currency.
Method calculates the transaction currency amount from an accounting currency given.
staticvoid main(Args _args)
CurrencyCode transCurrency = ‘AED’;
AmountCur amountCur;
AmountMst amountMST = 5500.00;
currencyExchangeHelper = CurrencyExchangeHelper::newExchangeDate(Ledger::primaryLedger(CompanyInfo::findDataArea("DUM").RecId), systemDateGet());
amountCur = currencyExchangeHelper.calculateAccountingToTransaction(transCurrency, amountMST ,true);
info(strFmt(‘%1’,amountcur));
d365technext: Pass field value from SalesTable to CustTrans in AX 2012 & D365FO Blog bot DAX Blogs 0 15.11.2018 09:11
d365technext: Create Contact Person for Vendor Or Customer AX 2012 & D365FO Blog bot DAX Blogs 0 01.11.2018 16:12
d365technext: Create Vendor using X++ D365FO & AX-2012 Blog bot DAX Blogs 0 03.09.2018 21:12
d365technext: Default Dimension D365FO AX-2012 Blog bot DAX Blogs 0 03.09.2018 21:12
d365technext: Record sorting D365FO, AX 7 and AX-2012 Blog bot DAX Blogs 0 08.08.2018 21:12
Часовой пояс GMT +3, время: 23:17.
