Старый 03.09.2018, 21:12   #1
d365technext: Create Vendor using X++ D365FO & AX-2012
Источник: http://d365technext.blogspot.com/201...o-ax-2012.html
Following Code will help you to create Vendor using X++
For Default Dimension please check Link
publicclassVendorHelper
privatevoidnew()
publicstaticVendorHelper construct()
returnnewVendorHelper();
publicvoid createVendor()
VendTable vendTable;
NumberSeq numberSeq;
Name name ='Systems Limited Karachi, Pakistan';
DirParty dirParty;
DirPartyPostalAddressView dirPartyPostalAddressView;
DirPartyContactInfoView dirPartyContactInfo;
container conAttribute=["BusinessUnit","CostCenter","Department"];
container conAttributeValue=["001","007","022"];
/* Marks the beginning of a transaction.
Necessary to utilize the method numRefCustAccount() */
ttsBegin;
vendTable.initValue();
try
//vendTable
//numberSeq = NumberSeq::newGetNum(VendParameters::numRefVendAccount())
// vendTable.AccountNum = numberSeq.num();
vendTable.AccountNum = "Vend-00099";
vendTable.VendGroup ='30';
vendTable.Currency ='USD';
vendTable.PaymTermId ='Net10';
vendTable.PaymMode ='CHECK';
vendTable.DefaultDimension=DefaultDimesnionHelper::createDefaultDimension(conAttribute,conAttributeValue);
vendTable.insert();
//DirParty
/* Creates a new instance of the DirParty class from an address book entity
that is represented by the custTable parameter. */
dirParty = DirParty::constructFromCommon(vendTable);
dirPartyPostalAddressView.LocationName ='Systems limited Karachi, Pakistan ';
dirPartyPostalAddressView.City ='Karachi';
dirPartyPostalAddressView.Street ='Shah-re-faisal alcope-house';
dirPartyPostalAddressView.StreetNumber ='18';
dirPartyPostalAddressView.CountryRegionId ='PAK';
dirPartyPostalAddressView.State ='Sindh';
dirPartyPostalAddressView.IsPrimary = NoYes::Yes;
// Fill address
dirParty.createOrUpdatePostalAddress(dirPartyPostalAddressView);
dirPartyContactInfo.LocationName ='Email Address';
dirPartyContactInfo.Locator ='ShaikhSohailHussain@gmail.com';
dirPartyContactInfo.Type = LogisticsElectronicAddressMethodType::Email;
dirPartyContactInfo.IsPrimary = NoYes::Yes;
// Fill Contacts
dirParty.createOrUpdateContactInfo(dirPartyContactInfo);
dirPartyContactInfo.LocationName ='Mobile Number';
dirPartyContactInfo.Locator ='923422722538';
dirPartyContactInfo.Type = LogisticsElectronicAddressMethodType::Phone;
// Fill Contacts
// Marks the end of transaction.
ttsCommit;
catch(Exception::Error)
ttsAbort;
throwException::Error;
d365technext: Environment Hot-Fixes List Using X++ D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 18:12
dynamicsaxse: February release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 02.03.2017 01:11
Часовой пояс GMT +3, время: 08:38.
