Fred Shen: Dialog screen events
Источник: http://fredshen.spaces.live.com/Blog...E4E3!160.entry
============== Some body may wonder if it is possible to use control's event methods in dialog just like what we do in the form. For instance, the change of a given dialog control's value will result in changes in other control's value. In Axapta, if you use a class that extends RunBase, it allows you to implement the screen events in dialog. 1. in dialog method protected Object dialog(…) { … dialog.allowUpdateOnSelectCtrl(true); … } Then, when a control is selected, the runbase.dialogSelectCtrl() method is called. 2. in dialogSelectCtrl method public void dialogSelectCtrl() { super(); //processing here } ![]() ![]() ============== Источник: http://fredshen.spaces.live.com/Blog...E4E3!160.entry |
