Старый 28.10.2006, 16:40   #1
Fred Shen: Convert Axapta date type value to datetime type value in SQL Server
Источник: http://fredshen.spaces.live.com/Blog...E4E3!171.entry
It is known that, in Axapta, date data type only contains values of day, month and year whereas in SQL Server, datetime data type contains values of second, minutes and hour as well.  So if you want to retrieve values from SQL Server using ODBCConnection, and you need to specify the condition on some date type comlumn, how can you get it done?
Here comes the code to show you how to convert Axapta’s date data type value to datetime value. It is an example to get a voucher value from LedgerTrans table in a given date.
static void TestDateTimeConversion(Args _args)
    LoginProperty             loginProperty = new LoginProperty();
    ODBCConnection      con;
    Statement                    stmt;
    str                                  sqlString, result;
    ResultSet                     resultSet;
    loginProperty.setServer('LocalServer');
    loginProperty.setDatabase('AXDB');
    loginProperty.setUsername('bmssa');
    loginProperty.setPassword('bmssa_pwd');
    con = new ODBCConnection(loginProperty);
    sqlString =   "SELECT * FROM LedgerTrans WHERE DATAAREAID=' "
                         curExt()
                         + " AND TRANSDATE CAST(' "
                         + date2str(str2date('20/02/2006',123),321,2,3,2,3,4)
                         + " ' AS datetime) ";
    stmt = Con.createStatement();
    resultSet = Stmt.executeQuery(sqlString);
    resultSet.next();
    result = resultSet.getString(1);
    if (result)
        info(result);
    else
        info( "No record! " );
Hope it helps.
mazzy: Сравнительное тестирование производительности Microsoft Axapta v.3.0. CУБД Microsoft SQL Server 2005 и Microsoft SQL Server 2000 Blog bot DAX Blogs 0 28.10.2006 17:22
Fred Shen: Date data type in Query Range Value Expression Blog bot DAX Blogs 0 28.10.2006 16:40
aEremenko: Диагностика проблем при установке Microsoft Dynamics Ax 4.0 на Microsoft SQL Server 2005 Blog bot DAX Blogs 0 28.10.2006 16:01
Доступ к VIEW SQL SERVER из Axapta 111andrei DAX: Программирование 13 02.12.2005 11:19
Часовой пояс GMT +3, время: 16:16.
