Старый 08.01.2010, 04:54   #1
25,643 / 848 (80) +++++++
lcash: Hebrew language
Источник: http://blogs.msdn.com/lcash/archive/...-language.aspx
I had a question about the Hebrew language on the demo VM. In Hotfix Rollup 3 the Hebrew language was enabled. You can apply HF RU3 on your demo VM but will have an issue because the VPC license needs to be updated.
We plan on including the HF RU3 on Refresh 3 VM which we are going to get out early in February.
Cheers
Lachlan
(Original post at http://blogs.msdn.com/lcash/)
lcash: Processing OLAP Cubes and AX Companies Blog bot DAX Blogs 0 15.10.2009 07:06
lcash: Using Project Time Sheets setting up the Period Code Blog bot DAX Blogs 0 31.07.2009 06:16
lcash: ProjPost Class compile error Blog bot DAX Blogs 0 24.07.2009 04:20
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 02:45.
