Старый 15.10.2009, 07:06   #1
lcash: Processing OLAP Cubes and AX Companies
Источник: http://blogs.msdn.com/lcash/archive/...companies.aspx
I’ve had this question a few times from partners so thought I’d post a note. To get updated transactional data into the OLAP cubes you will have to process the cubes in SQL Analysis Services. The question I’ve had relates to adding new companies in Dynamics AX.
In the SQL Management Studio there are two places to process cubes on the cube itself and at the database level. If you process at the cube level it doesn’t re-calculate the entire DB and so you won’t get new companies. So make sure you process at the database level. For example on the demo VM
1. Click Start\All Programs\Microsoft SQL Server 2005\SQL Management Studio.
2. When it opens connect to Analysis Services
3. When you expand the tree you will find the databases for example “Dynamics AX” on the demo VMs. if you expand the tree further you will see the cubes. If you right click on the database level of on a cube you will get a Process option on the submenu.
4. Only processing at the database level eg “Dynamics AX” on the demo VMs will update the whole OLAP db and pick up new AX companies you might have created.
It will take a minute or 2 to process depending on the data you have and the machine you are running on.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash
За это сообщение автора поблагодарили: Poleax (0).
lcash: Default Cubes Advisor Tool for Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 21.07.2009 10:05
Microsoft Dynamics AX 2009 White Paper: Extending Default Cubes for Virtual Companies Vadik DAX: База знаний и проекты 0 31.03.2009 09:56
Microsoft Dynamics AX 2009 White Paper: Configure the Default OLAP Cubes Vadik DAX: База знаний и проекты 0 06.01.2009 19:36
AX UK: Repairing the AX 2009 OLAP Cubes where License/Config keys are switched off Blog bot DAX Blogs 0 03.12.2008 19:05
gatesasbait: On Dynamics AX 2009 Perspectives, OLAP Cubes and Analysis Server Blog bot DAX Blogs 0 02.07.2008 19:06
Часовой пояс GMT +3, время: 07:39.
