Старый 03.08.2018, 18:11   #1
d365technext: FormHasMethod extension in D365FO
Источник: http://d365technext.blogspot.com/201...in-d365fo.html
Every developer who has start working on D365FO face this issue that when we create method in form Extension
For verification of method exists or not in run time we can use Global::formHasMethod but it does not work with form extensions
So i advise everyone to use below code its working...
[ExtensionOf(classStr(Global))]
finalclass SLD_Global_Extension
staticboolean formHasMethod(FormRun _formRun, IdentifierName _methodName)
boolean ret = next formHasMethod(_formRun, _methodName);
if (!ret)
ret = Global::VerifyformHasMethod((_formRun, _methodName);
return ret;
privatestaticboolean VerifyformHasMethod (FormRun _formRun, IdentifierName _methodName)
try
System.Object[] extensions = Microsoft.Dynamics.Ax.Xpp.ExtensionClassSupport::GetExtensionsOnType(_formRun.GetType(), true);
if (extensions)
System.Type formRunExtensionType;
System.Reflection.MethodInfo methodInfo;
//extension methods are always static
var bindingFlags = BindingFlags::Public | BindingFlags::Static | BindingFlags::IgnoreCase;
for (int i = 0; i < extensions.Length; i++)
formRunExtensionType = extensions.GetValue(i);
var methodsInfo = formRunExtensionType.GetMethods(bindingFlags);
for (int n = 0; n < methodsInfo.get_Length(); n++)
methodInfo = methodsInfo.getValue(n);
if (methodInfo.Name == _methodName)
returntrue;
catch (Exception::CLRError)
error(CLRInterop::getLastException().ToString());
returnfalse;
d365technext: Card Pattern in Grid D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 11:11
d365technext: Batch Multi threading D365FO AX7 Blog bot DAX Blogs 0 31.07.2018 23:16
d365technext: Task Recorder D365FO Blog bot DAX Blogs 0 31.07.2018 17:11
d365technext: Private, Protected and Public attribute access in Class Extension Blog bot DAX Blogs 0 30.07.2018 20:13
ievgensaxblog: D365FOE. FormHasMethod extension for form extension methods. Blog bot DAX Blogs 0 16.11.2017 10:11
Часовой пояс GMT +3, время: 10:18.
