Старый 02.08.2018, 11:11   #1
d365technext: Card Pattern in Grid D365FO & AX 7
Источник: http://d365technext.blogspot.com/201...65fo-ax-7.html
Yesterday, One of my team member had task to show data in Grid in Card Style like work space, in the initial state we were trying to create work space tile dynamically but no luck.
After spending hour i found an page with pattern design Card.
Here are the some steps to achieve the below task.
Step-1 Create Custom form and data-source and Grid,
Step-2 apply the patter of list page on design node of the form and follow the design pattern instruction.
Step-3 Now select the grid and change the following properties of Grid.
  1. Style= List
  2. Extended Style= CardList
Step-4 Now add the Group in the grid and apply the pattern of business Card.
Step-5 Follow the instruction of business card design pattern and add the required field.
Step-6 Create Display menu item set object properties with you newly created form.
Step-7 Create menu extension and drag the display menu item on it
Step-8 Last steps to perform build and sync.
Now login on you D365FO instance and verify the form...
for me its working fine, kindly check the below screenshot for reference.
Please feel free to contact me if you are facing any issue during implementation of this blog.
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
dynamics-coe: VISA VCF plain text credit card statement into Dynamics AX with XSLT Blog bot DAX Blogs 1 10.12.2015 12:30
dynamics-ax: Microsoft Dynamics AX 2012 - Launch Event, Training Plans & WPC 2011 Blog bot DAX Blogs 0 13.07.2011 22:11
Часовой пояс GMT +3, время: 20:51.
