Старый 29.08.2008, 21:10   #1
axaptapedia: Create New AOT Project From Template
Источник: http://www.axaptapedia.com/Create_Ne..._From_Template
Summary: If you want to automatically create a project from a Template Project (An Empty Project with just the AOT Structure for example), then you can use this code as a helpful guideline.
 //  Takes a Template Project Name and a Target Project Name
 //  and automatically creates a new Project from a Template Project.
 static void CreateNewAOTProjectFromTemplate(Args _args)
     ProjectNode     templateproject;
     ProjectNode     pretargetproject;
     ProjectNode     targetproject;
     TreeNode        sharedProject;
     UtilElements    utilElement;
     str             templateprojectname;
     str             pretargetprojectname;
     str             targetprojectname       = 'AATest';
     str pretargetprojectname()
         return pretargetprojectname;
     // Get the templateprojectname from someplace where the name of a Template project can be found.
     // NOTE:  You'll need to change this Line and assign your own Template name.
     templateprojectname   = DPA_Parameters::find().AOTProjectTemplate;
     sharedProject   = SysTreeNode::getSharedProject();
     if (sharedProject.AOTfindChild(targetprojectname))
         return;
     // Find the Template Project and load it for inspection
     templateproject   = sharedProject.AOTfindChild(templateprojectname);
     if (!templateproject)
         return;
     templateproject.loadForInspection();
     // Duplicate the Template Project using an intermediary ProjectNode
     pretargetproject   = templateproject.AOTDuplicate();
     pretargetproject.AOTsave();
     // Get the name of the duplicated project  - CopyOf%1 (%1 = whatever the Template name is)
     pretargetprojectname    = pretargetproject.AOTname();
     // Rename the duplicated Project to the desired project name.
     // NOTE: I tried other ways, but this is the only way that worked!
     //       And, it's fast!
     ttsbegin;
     select firstonly forupdate utilElement
         where utilElement.recordType == UtilElementType::SharedProject
            && utilElement.name       == pretargetprojectname();
     if (utilElement)
         utilElement.name = targetprojectname;
         utilElement.doUpdate();
     ttscommit;
     // Have to refresh the SharedProject Node  -  Very important!
     sharedProject.AOTrefresh();
     // Now just get the new project and open it.
     targetproject   = sharedProject.AOTfindChild(targetprojectname);
     targetproject.AOTrun();
За это сообщение автора поблагодарили: alex55 (1).
dax-lessons: Create Technical Document from AX Blog bot DAX Blogs 0 12.03.2008 09:05
axaptapedia: Control AOS from command line Blog bot DAX Blogs 0 09.03.2007 14:50
Dynamics AX: Dynamics AX - Create a Layer Project Blog bot DAX Blogs 0 28.10.2006 16:40
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 09:57.
