Старый 12.03.2008, 09:05   #1
dax-lessons: Create Technical Document from AX
Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!139.entry
Creating detail technical document in projects is very time consuming. Isn’tit?
Particularly if there are many objects in the project it will take more timein creating it.
The jobs which I am going to explain will reduce time in preparing technicaldocument.
This job will list the table fields properties like table field name,help text(Description),type, Size etc.
static voidsgx_TehnicalDocument_Tables(Args _args)
   COM         document;
   COM         wordDocument;
   COM         wordRange;
   COM         app;
   str         tableContent;
   SysDictTable    dictTable;
   SysDictField    dictField;
   Counter         fieldCounter;
   Counter         arrayCounter;
   str typeofTheField(DictField df, Types _types)
       str typeName;
       SysDictType dictType;
       SysDictEnum dictEnum;
       switch(_types)
            case Types::UserType    :  dictType = new SysDictType(dictField.typeId());
                                        returndictType.name();
            case Types::Container   :  return 'container';
            case Types::Date        :  return  'date';
            case Types::Enum        :  dictEnum = new SysDictEnum(dictField.enumId());
                                        if(dictEnum)
                                           return dictEnum.name();
            case Types::Integer     :
                                       return  'int';
             case Types::Int64       :
                                       return  'int64';
             case Types::Real        :
                                       return  'real';
             case Types::Record      :
                                       return  'record';
            case Types::VarString   :
            case Types::RString     :
            case Types::String      :  return  'str';
            case Types::BLOB        :  return  'blob';
            case Types::DateTime    : return  'datetime' ;
            case Types::Guid        : return  'guid' ;
            default : return '';
   app = new com("Word.Application");
   app.visible(true);
   document     = app.Documents();
   wordDocument = document.add();
   wordDocument.activate();
   wordRange   =wordDocument.range(0,0);
   dictTable = new SysDictTable(tablenum(CustTable)); // Mention your table here
<strong><span style="color:rgb(153, 51, 102);font-weight:normal">   for (fieldCounter = 1; fieldCounter
Arijit Basu: AX 2009 Document Management & MOSS / WSS Blog bot DAX Blogs 0 23.01.2009 01:07
dax-lessons: Create Outlook Appointment or Meeting Request using X++ Blog bot DAX Blogs 0 30.04.2008 23:07
dax-lessons: Create HTML using HtmlTextWriter class in x++ Blog bot DAX Blogs 0 15.04.2008 20:05
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
Dynamics AX: Make use of DotNet Assemblies from DAX 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 08:11.
