Старый 12.05.2010, 16:41   #11
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Event ID 1000 Source Microsoft.Dynamics.Framework.Portal
http://eventid.net/display.asp?event...Portal&phase=1
Ax 2009 OLAP
Configuration keys
The predefined cubes require full license keys. If any configuration keys are disabled, related
tables and fields are automatically removed when the Microsoft Dynamics AX database is
synchronized. Similarly, when the OLAP database is synchronized with the Microsoft Dynamics
AX database, some related cube components are removed. In this case, you must manually
remove those elements of the cube, such as key performance indicators (KPIs), calculated
measures, and dimensions based on named queries, before you can successfully process the
cubes.
Use the error messages that appear in the synchronization log as your guide to the
elements that must be removed.
For a list of tables and configuration keys that are used by each cube, see the following topics:
  •  General ledger cube
  •  Accounts receivable cube
  •  Accounts payable cube
  •  Expense management cube
  •  Project accounting cube
  •  Sales cube
  •  Purchase cube
  •  Production cube
  •  Customer relationship management cube
  • Human resource management cube
Microsoft Dynamics AX 2009 Business Intelligence Cube Reference Guide
Последний раз редактировалось Poleax; 12.05.2010 в 17:29.
ax2009, olap, ssas, ssrs
Ошибка (?) при печати приходного ордера в DAX 4.0 SP2 Ivanhoe DAX: Программирование 7 19.01.2021 14:13
Ошибка в логе при установке клиента AX 2009 sao DAX: Администрирование 9 04.02.2010 11:56
Ошибка при установке корпоративного портала ax2009, ошибка доступа Antant DAX: Администрирование 0 11.09.2009 09:28
Ошибка при сохранении поставщика Filip DAX: Функционал 19 24.02.2004 08:32
Часовой пояс GMT +3, время: 10:29.
