		#11 |
			Event ID 1000 Source Microsoft.Dynamics.Framework.Portal
			http://eventid.net/display.asp?event...Portal&phase=1 Ax 2009 OLAP Цитата:
			Configuration keys
The predefined cubes require full license keys. If any configuration keys are disabled, related tables and fields are automatically removed when the Microsoft Dynamics AX database is synchronized. Similarly, when the OLAP database is synchronized with the Microsoft Dynamics AX database, some related cube components are removed. In this case, you must manually remove those elements of the cube, such as key performance indicators (KPIs), calculated measures, and dimensions based on named queries, before you can successfully process the cubes. Use the error messages that appear in the synchronization log as your guide to the elements that must be removed. For a list of tables and configuration keys that are used by each cube, see the following topics:
   Microsoft Dynamics AX 2009 Business Intelligence Cube Reference GuideПоследний раз редактировалось Poleax; 12.05.2010 в 17:29.  |
