Старый 04.08.2006, 14:09   #3
Recoilme is offline
Recoilme
злыдень
Аватар для Recoilme
895 / 192 (8) ++++++
Thumbs up Microsoft жжёт
Нет, я просто тащусь от этой компании ))
По приведенной мази ссылке, цитирую:
Direct SQL
When direct SQL is used through the Connection and Statement classes, it is subject to SQL injection threats. Classes that wrap these kernel classes—for example, the SysSQLBuilder classes—are equally dangerous. You should keep in mind that record-level security and field-level security are not enforced on the Statement class.
To learn more about SQL injection attacks, see the article, Stop SQL Injection Attacks Before They Stop You, on MSDN.
Ля-ля-ля - не юзайте прямой SQL пока он не поюзал Вас.
Открываем Читвёртую Аксапту, и что мы там видим? Правильно! Прямой SQL)))
/* This method will build following statement in a str:
execute sp_executesql N'UPDATE InventSum
    SET InventSum.CostAmountPhysical     = InventSum.CostAmountPhysical            +
                                           InventSumDelta.SUM_CostAmountPhysical,
        InventSum.PostedValue            = InventSum.PostedValue                   +
                                           InventSumDelta.SUM_PostedValue,
        InventSum.Qty                    = InventSum.Qty                           +
                                           InventSumDelta.SUM_Qty,
        InventSum.LastUpdDatePhysical    = CASE WHEN InventSum.LastUpdDatePhysical > InventSumDelta.MAX_LastUpdDatePhysical
                                                THEN InventSum.LastUpdDatePhysical
                                                ELSE InventSumDelta.MAX_LastUpdDatePhysical
                                           END,
        InventSum.LastUpdDateExpected    = CASE WHEN InventSum.LastUpdDateExpected > InventSumDelta.MAX_LastUpdDateExpected
                                                THEN InventSum.LastUpdDateExpected
                                                ELSE InventSumDelta.MAX_LastUpdDateExpected
                                           END,
        InventSum.ClosedQty              = CASE WHEN ((InventSum.PostedQty + InventSumDelta.SUM_PostedQty) = 0 AND
                                                      (InventSum.Deducted  + InventSumDelta.SUM_Deducted)  = 0 AND
                                                      (InventSum.Picked    + InventSumDelta.SUM_Picked)    = 0 AND
                                                THEN 1
                                                ELSE 0
                                           END,
        InventSum.Closed                 = CASE WHEN ((InventSum.PostedValue    + InventSumDelta.SUM_PostedValue)  = 0 AND
                                                     (InventSum.PhysicalValue  + InventSumDelta.SUM_PhysicalValue) = 0 AND
                                                THEN 1
                                                ELSE 0
                                           END
    FROM (SELECT SUM(CostAmountPhysical)    AS SUM_CostAmountPhysical,
                 SUM(PostedValue)           AS SUM_PostedValue,
                 SUM(Qty)                   AS SUM_Qty,
                 .....                      AS ...,
                 .....                      AS ...,
                 MAX(LastUpdDatePhysical)   AS MAX_LastUpdDatePhysical,
                 MAX(LastUpdDateExpected)   AS MAX_LastUpdDateExpected,
                 InventSumDelta.ItemId,
                 InventSumDelta.InventDimId
          FROM InventSumDelta
          WHERE InventSumDelta.DataAreaId   = @p1
          AND   InventSumDelta.TTSId        = @p2
          AND   InventSumDelta.IsAggregated = 0
          GROUP BY InventSumDelta.ItemId, InventSumDelta.InventDimId
         ) AS InventSumDelta
    WHERE InventSum.DataAreaId        = @p1
    AND   InventSum.ItemId            = InventSumDelta.ItemId
    AND   InventSum.InventDimId       = InventSumDelta.InventDimId
',N'@p1 NVARCHAR(3), @p2 BIGINT',@p1=%1, @p2='%2'
Прошу завести пользователя Майкрософт, я ему рейтинг понижать/повышать буду))
что нового, ax3.0, ax4.0
Как сделать AND между двумя датасорсами на одном уровне в query rkorchagin DAX: Программирование 15 15.01.2009 17:42
Разница между запросами Rect DAX: Программирование 13 05.12.2006 12:44
Расчеты между компаниями Yuri Nikitenko DAX: Функционал 9 15.11.2004 08:49
различие между Axapta и Attain andreynikolai DAX: Программирование 4 04.02.2004 17:53
дизайн отчета (как сделать его с разделителями между столбцами?) puz DAX: Программирование 7 02.09.2003 08:50
Часовой пояс GMT +3, время: 06:28.
