Старый 13.04.2007, 04:22   #1
tomb: Documentation on Biztalk Adapter
Источник: http://blogs.msdn.com/tomb/archive/2...k-adapter.aspx
There's a great feature in AX4.0, namely the application integration framework. The great thing is it can connect to virtually every other environment. Especially if you hook it up to Biztalk (2006 in this case). On Partnersource, there's a great document describing how to set up the whole thing. It's more than just a marketing doc, but a very extensive guide (more than 100 pages) on the ins and outs of this Biztalk connection. Go check it out.
Microsoft Dynamics AX 2009 AIF BizTalk Adapter Configuration White Paper Vadik DAX: База знаний и проекты 3 18.11.2016 01:04
Dianne Siebold: AIF BizTalk Adapter White Paper Updated for 2009 Blog bot DAX Blogs 0 31.01.2009 11:05
AX UK: AIF BizTalk Adapter Configuration White Paper Blog bot DAX Blogs 0 27.01.2009 10:05
Dynamics AX: Microsoft Dynamics AX - Application integration, BizTalk Adapter install possible error Blog bot DAX Blogs 0 26.08.2008 00:11
tomb: Microsoft Dynamics AX 4.0 SP1 Application Documentation Hotfix Blog bot DAX Blogs 0 12.03.2007 15:30
Часовой пояс GMT +3, время: 15:39.
