Старый 31.07.2007, 15:00   #1
axcoder: Unwanted fields fetching when selecting by unique index
Источник: http://axcoder.blogspot.com/2007/07/...selecting.html
Last friday i was optimizing a form with a lof of display fields with an implementation like the following:
display EmplName emplName()
  return EmplTable::find(this.EmplID).Name;
The one of sources to increase performance of such code is to select only fields which will be used lately. So I have replaced this code with the following:
  return this.EmplID ?
         (select Name from EmplTable
              where EmplTable.emplID==this.EmplID).Name
but when I enabled SQL tracing, I found, that this code producess select with ALL fields of EmplTable.
It was strange... With a great help of my co worker, i've found the following:
  • when there is only fields of any unique index in the where condition, all fields are fetched
  • when there is an extra field in the condition, only required fields is selected (and the extra fields in where)
  • So I converted previously mentioned methods to the following:
                     EmplTable.recID
          ).Name
palleagermark: Saving the reference to a unique record as a string Blog bot DAX Blogs 0 20.10.2008 11:05
axaptafreak: Getting new table fields into your form datasource Blog bot DAX Blogs 2 24.01.2008 22:51
Dynamics AX: SQL Tuning: Table & Index Scans Blog bot DAX Blogs 0 20.07.2007 11:50
Fred Shen: Tips on optimizing primary index in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 08:13.
