Старый 29.12.2007, 19:50   #1
25,643 / 848 (80) +++++++
Ruslan Goncharov: How to add a document into AX programmically? (Document handling)
Источник: http://rusgon.blogspot.com/2007/12/h...t-into-ax.html
As a matter of fact it's pretty easy.
Following lines allow you do this.
void saveIntoDocuRefTable()
    DocuValue docuValue;
    DocuRef docuRef;
    Container cFile;
    BinData binData;
    DocuTypeId _docuTypeId = ...;
    binData = new BinData();
    binData.loadFile(fileName);
    cFile = Docu::splitFileName(fileName);
    docuValue.fileName = conpeek(cFile,1);
    docuValue.path = conpeek(cFile,3);
    docuValue.fileType = conpeek(cFile,2);
    docuValue.File = binData.getData();
    docuValue.insert();
    docuRef.ValueRecId = docuValue.recId;
    docuRef.RefCompanyId = CurExt();
    docuRef.RefTableId = tableNum(....);
    docuRef.RefRecId = .....;
    docuRef.TypeId = _docuTypeId;
    docuRef.Name = fileName;
    docuRef.Notes = ....;
    docuRef.insert();
    WinApi::deleteFile(fileName);
Ruslan Goncharov: How to clarify what happened with variables in AX Blog bot DAX Blogs 0 17.01.2008 15:40
Ruslan Goncharov: How to get the screenshots of all open windows in AX Blog bot DAX Blogs 0 12.01.2008 12:31
Ruslan Goncharov: How to get list of all open windows and their names in AX Blog bot DAX Blogs 0 29.12.2007 19:50
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 17:49.
