Старый 16.06.2008, 16:01   #5
konopello is offline
konopello
SAP
SAP
628 / 76 (4) ++++
Всем спасибо, проблему решил
static str OEMToCharBuff(str _strSource)
    DLL         winApiDLL = new DLL('USER32');
    DLLFunction OEMToChar = new DLLFunction(winApiDLL, 'OemToCharA');
    Binary      bSource   = new Binary(_strSource);
    str         oemstr;
    OEMToChar.returns(ExtTypes::DWORD);
    OEMToChar.arg(ExtTypes::POINTER, ExtTypes::POINTER);
    OEMToChar.call(bSource, bSource);
    oemstr = bSource.string(0);
    return oemstr;
static void A000088_WorkXML(Args _args)
    TextBuffer                  textBuffer;
    XmlDocument                 xmlDoc;
    XMLNodeList                 tests;
    XMLNode                     node;
    XMLParseError               error;
    XmlProcessingInstruction    xmlProcessingInstruction;
    FileIOPermission    sourceFileReadPerm;
    Filename            sourceFileName = 'C:\\Tmp\\101.xml';
    #define.read('R')
    #define.write('W')
    // Assert permission to use XML save
    sourceFileReadPerm = new FileIOPermission(sourceFileName, #read);
    sourceFileReadPerm.assert();
    textBuffer = new TextBuffer();
    textBuffer.fromFile(sourceFileName);
    textBuffer.setText(WinApi::OEMToCharBuff(textBuffer.getText())); // А ВОТ И ПЕРЕВОД
    xmlDoc = new XmlDocument();
    if (!xmlDoc.loadXML(textBuffer.getText()))
        error = xmlDoc.parseError();
        info("Error during load of XML: " + error.reason() + " in line " + int2str(error.line()));
        return;
    tests = xmlDoc.selectNodes('//Statements');
    node = tests.nextNode();
    while (node)
        info(node.selectSingleNode('Date').text());
        info(node.selectSingleNode('Account').text());
xml, ax4.0
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
axStart: InfoPath with default AIF file inbound offline Blog bot DAX Blogs 0 20.05.2008 19:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Dave: XML File Size limitation using FindList AIF Actions Blog bot DAX Blogs 0 12.04.2007 16:10
Axapta Lessons: Export a table to a file Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 02:52.
