Старый 07.07.2008, 12:35   #3
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 646 (26) +++++++
The thing is that the garbage collector cleans up objects only when they go out of scope. Sometimes an object can stay in scope for quite a while holding its memory (especially if .net client stays logged in, logging out forces all object handles to be released). There's a good advice on how to avoid objects staying in scope for too long - always use the using statement.
Vincent: Debugging business logic in AX 2009 SSRS reports Blog bot DAX Blogs 0 29.11.2008 09:05
Dynamics AX: Map Object Sorting - a real issue Blog bot DAX Blogs 7 15.10.2008 12:02
axStart: A structure way off dealing with garbage collection & memory leaks with the Dynamics AX .net connector. Blog bot DAX Blogs 0 31.07.2008 22:05
SysDictCoder: 10 tips for debugging in Dynamics Ax Blog bot DAX Blogs 0 01.07.2007 22:05
Dynamics AX: .Net BC, C# - Working with AxaptaRecord Object Blog bot DAX Blogs 0 20.06.2007 23:13
Часовой пояс GMT +3, время: 07:04.
