Старый 29.08.2008, 03:15   #1
25,644 / 848 (80) +++++++
gatesasbait: Something to check if the Dynamics AX 4 client crashes upon startup
Источник: http://gatesasbait.spaces.live.com/B...B9F5!245.entry
Good morning,
If you get the following error when starting up a Dynamics AX 4 client and just can't see anything wrong with the configuration or anything else; look into the following folder on your local machine "\Documents and Settings\\Local Settings\Application Data\" for a file named "ax__.auc" and rename it or delete it. This file stores a local cache of objects and for some reason that I don't know, sometimes gets corrupted.
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
gatesasbait: Something to check if the Dynamics Ax 4 client throws the "failed to logon to axapta" error Blog bot DAX Blogs 0 08.09.2008 19:05
Часовой пояс GMT +3, время: 06:53.
