Microsoft Dynamics CRM Team Blog: How to track the progress of entity customizations import
Источник: http://blogs.msdn.com/crm/archive/20...ns-import.aspx
============== Have you ever wanted to see the progress information while importing entity customizations?Now you can track the import progress by using new Microsoft Dynamics CRM import job entity. The import job entity tracks the results when you import entity customizations or translations from an XML file into Microsoft Dynamics CRM. The import process is created when you execute one of the following messages: · ImportXmlWithProgressThe import operation creates an import job entity instance and updates the importjob.data property with progress information. You can learn more about starting an import operation and monitoring the progress by reading the following topics in Microsoft Dynamics CRM 4.0 SDK at http://msdn.microsoft.com/en-us/library/cc151162.aspx: · Import Job Entity CapabilitiesCheers, Inna Agranov Источник: http://blogs.msdn.com/crm/archive/20...ns-import.aspx
