Старый 18.12.2008, 16:17   #21
Ириска is offline
Ириска
Аватар для Ириска
22 / 11 (1) +
Прислали логи. Там две ошибки, в основном, повторяются
Error: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
Error Message: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
Source File: Not available
Line Number: Not available
Request URL: http://crm.mediachase.com:5555/MSCRM...rmService.asmx
Stack Trace Info: [SqlException: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)]
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
и вот такая:
System.Net.WebException: The request failed with HTTP status 400: Bad Request.
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at CrmDiagTool4.CrmDeploymentSdk.CrmDeploymentService.Execute(DeploymentServiceRequest Request)
at CrmDiagTool4.Sdk.RetrieveOrganizationsProperties(CrmService crmsvc, CrmDeploymentService crmdeploysvc, CrmAuthenticationToken token)
at CrmDiagTool4.Sdk.get_AllOrganizationDictionnary()
at CrmDiagTool4.Form1.WriteSDKAllOrganizationInfo(StreamWriter sw)
И в чем тут именно проблема?
Microsoft Dynamics CRM Team Blog: Reports for CRM 4.0 using SQL Server 2008 and Report Builder 2.0 Blog bot Dynamics CRM: Blogs 0 11.11.2008 08:05
Microsoft Dynamics CRM Team Blog: Top 14 Microsoft Dynamics CRM Sites and Downloads Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 09:10.
