Старый 30.03.2009, 11:40   #9
Lucky13 is offline
Lucky13
714 / 198 (8) ++++++
Сообщение от Yprit Посмотреть сообщение
Что-то я там такого не увидел Можете носом тыкнуть? У меня 4-ка.
У меня 3.0 SP3
Класс SQLDatabaseInit
boolean insertSystemVariablesSqlServer()
    int indexValue =    #indexSupported+
                        #indexQualifier+
                        #recidsPerCompany+
                        #TransidsPerCompany;
    if (sqlSystem.dbRequestedUnicodeEnabled()>0)
        this.insertSystemVariable('(\'STR\',\'NVARCHAR(\%u)\',1,NULL)');
    else
        this.insertSystemVariable('(\'STR\',\'VARCHAR(\%u)\',1,NULL)');
    this.insertSystemVariable('(\'INT\',\'INT\',1,NULL)');
    this.insertSystemVariable('(\'REAL\',\'NUMERIC(28,12)\',1,NULL)');
    this.insertSystemVariable('(\'DATE\',\'DATETIME\',1,NULL)');
    this.insertSystemVariable('(\'ENUM\',\'INT\',1,NULL)');
    this.insertSystemVariable('(\'BLOB\',\'IMAGE\',1,NULL)');
    this.insertSystemVariable('(\'TEXT\',\'TEXT\',1,NULL)');
    this.insertSystemVariable('(\'TIMESTAMPTYPE\',\'\',1,NULL)');
    this.insertSystemVariable('(\'GETINDEX\',\'SELECT name FROM sysindexes WHERE indid>0 AND indid<255 AND id=object_id(\'\'\%s\'\') AND INDEXPROPERTY(id, name, \'\'IsStatistics\'\') = 0\',3,NULL)');
    this.insertSystemVariable('(\'RENAME\',\'EXECUTE SP_RENAME \%s,\%s\',3,NULL)');
    this.insertSystemVariable('(\'KEYWORDS\',\'PROC,SUM,LINENO,OPEN,TRANSACTION,BY,PERCENT,PROCEDURE,CURRENT_DATE,CURRENT_TIME,CURRENT_USER,DUMMY,PERMANENT,PIPE\',4,NULL)');
    this.insertSystemVariable('(\'SHADOW\',\'$\',5,NULL)');
    this.insertSystemVariable('(\'INDEXCLUSTER\', \'CLUSTERED\',5,NULL)');
    this.insertSystemVariable('(\'QUOTEPRE\',\'\',6,NULL)');
    this.insertSystemVariable('(\'QUOTEPOST\',\'_\',6,NULL)');
    this.insertSystemVariable('(\'DBNAME\',\'Microsoft SQL Server\',7,NULL)');
    this.insertSystemVariable('(\'DUPLICATEKEY\',\'+2601,+2627\',9,NULL)');
    this.insertSystemVariable('(\'DEADLOCKCODES\',\'+1205\',9,NULL)');
    this.insertSystemVariable('(\'TIMESTAMPCODES\',\'+532\',9,NULL)');
    this.insertSystemVariable('(\'DISCONNECTCODES\',\'+230,+10054\',9,NULL)');
    this.insertSystemVariable('(\'CTRLBRKCODES\',\'\',9,NULL)');
    this.insertSystemVariable('(\'SHARINGCODES\',\'\',9,NULL)');
    this.insertSystemVariable('(\'RECORDLOCKCODES\',\'\',9,NULL)');
    this.insertSystemVariable('(\'DONTRETRYCODES\',\'+100\',9,NULL)');
    this.insertSystemVariable('(\'INDEXEXISTCODES\',\'\',9,NULL)');
    this.insertSystemVariable('(\'ENDOFDATACODES\',\'+100\',9,NULL)');
    this.insertSystemVariable('(\'LOGFULLCODES\',\'+1105\',9,NULL)');
    this.insertSystemVariable('(\'SYNCHRONIZECODES\',\'+207,+208,+1913,+3701,+3702,+3703\',9,NULL)');
    this.insertSystemVariable('(\'TABLENAMELEN\',\'30\',10,NULL)');
    this.insertSystemVariable('(\'FIELDNAMELEN\',\'30\',10,NULL)');
    this.insertSystemVariable('(\'CHARSET\',\'1\', 11,NULL)');
    this.insertSystemVariable('(\'SORTMODE\',\'1\',11,NULL)');
    this.insertSystemVariable('(\'CONCURRENCY\',\'6\',11,NULL)');
    this.insertSystemVariable('(\'NULLSUPPORT\',\'3\',11,NULL)');
    this.insertSystemVariable('(\'DBID\',\'2\',12,NULL)');
    this.insertSystemVariable('(\'SYSVARID\',\''+ int2str(#currentSysVarId) +'\',12,NULL)');
    this.insertSystemVariable('(\'RESERVED\',\'0\',12,NULL)');
    this.insertSystemVariable('(\'ALTERTABLE\',\'1\',13,NULL)');
    this.insertSystemVariable('(\'GETDATA\',\'0\',13,NULL)');
    this.insertSystemVariable('(\'SQLFUNCTIONS\',\'0\',13,NULL)'); // 2000/8/10: MAX() and MIN() handled by the SQL backend
    this.insertSystemVariable('(\'INDEX\',\''+int2Str(indexValue)+'\',13,NULL)');
    this.insertSystemVariable('(\'APICALLSPINCNT\',\'0\',15,NULL)');
    this.insertSystemVariable('(\'APICALLSLEEP\',\'10\',15,NULL)');
    this.insertSystemVariable('(\'CASESENSITIVE\',\'0\',20,NULL)');
    this.insertSystemVariable('(\'ALLOWEMPTYSTRING\',\'1\',20,NULL)');
    this.insertSystemVariable('(\'COMMENTSTRING\',\'1\',20,NULL)');
    this.insertSystemVariable('(\'NAMETRUNCFIX\',\'0\',20,NULL)');
    this.insertSystemVariable(strFmt('(\'UNICODEENABLED\',\'%1\',20,NULL)',sqlSystem.dbRequestedUnicodeEnabled()));
    this.insertSystemVariable('(\'ORDERBYSELECT\',\'0\',21,NULL)');
    return TRUE;
Строка для типа REAL :
баг, ax3.0, ax4.0
axStart: How to convert a column in a table to a different type with the same name without losing data. Blog bot DAX Blogs 0 01.02.2008 21:21
jerry-dynamics: Where can you drag and drop an extended data type to? Blog bot DAX Blogs 0 16.06.2007 11:20
Fred Shen: Date data type in Query Range Value Expression Blog bot DAX Blogs 0 28.10.2006 16:40
Ошибка "Restricted data type attribute violation." kalex DAX: Программирование 4 24.12.2002 14:24
Часовой пояс GMT +3, время: 16:59.
