Старый 29.06.2009, 19:05   #1
25,626 / 848 (80) +++++++
msdynamicsax: Unable to debug Enterprise Portal running on Windows Server 2008
Источник: http://msdynamicsax.wordpress.com/20...s-server-2008/
I have been in contact with MS Premium Support today and thay have informed me that debugging X++ code that executes in IIS (Enterprise Portal) will not work when the webserver is using Windows Server 2008. This is due to the redesign of terminal services processes that ensures that windows services will have exclusive access to Session 0. In previous versions, you could log on to the console either phisically or using remote desktop and /console or /admin -flags to log on to Session 0.
This is not possible in Windows Server 2008 and the result is that the debugger is unable to attach to the IIS process.
Microsoft is working on a hotfix, but does not know when it will be released.
The only option as of now is to downgrade the OS (reinstall) to Windows Server 2003.
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
jinx: Microsoft Dynamics AX 2009, Windows Server 2008 und SQL Server 2008 Blog bot DAX auf Deutsch 0 12.10.2008 20:10
msdynamicsax: Enterprise Portal development in DAX 2009 Blog bot DAX Blogs 0 18.04.2008 07:06
Solutions Monkey: Convergence 2008 - Microsoft Dynamics AX Enterprise Portal and Role Centers Blog bot DAX Blogs 0 09.03.2008 17:07
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
Часовой пояс GMT +3, время: 06:06.
