Старый 22.07.2009, 09:05   #1
25,644 / 848 (80) +++++++
lcash: Setting up external networking on the Demo VMs
Источник: http://blogs.msdn.com/lcash/archive/...-demo-vms.aspx
I’ve had a few questions that relate to how to use external networking on the demo VMs. In the in the notes about the setup of the VMs it is recommended that you have the second network card disabled to help start up time.
However if you need to get out on the internet of use an external network for example :
  • Get out to a public web site.
  • Activate Office is office thinks the machine has changed, usually a result of moving to different virtualization technology like Win7 VPC7 or Hyper-V.
  • Use Office Communicator to connect to your internal OCS infrastructure.
  • Remote Desktop (RDP) e.g. use Terminal services to connect into the VM.
This video will help you out to get connected
Double click to view full screen.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash/
lcash: Having trouble starting the AOS on the Demo VM ? Blog bot DAX Blogs 0 22.07.2009 02:06
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
lcash: Setting up Outlook Sync from Dynamics AX Blog bot DAX Blogs 0 21.07.2009 10:05
lcash: Quick update on the Refresh2 VMs Blog bot DAX Blogs 0 03.07.2009 08:05
Jim Wang: CRM 4.0 External Connector License Blog bot Dynamics CRM: Blogs 0 11.02.2009 06:05
Часовой пояс GMT +3, время: 22:57.
