Старый 13.08.2009, 15:05   #1
25,617 / 848 (80) +++++++
jamesdowney: Pulling Attribute Values into Variables from FetchXML Result
Источник: http://www.jamesdowney.net/blog/post...ML-Result.aspx
Over the years, I've recieved several emails from users of FetchXML Builder about how to pull the data retreived by CrmService Fetch method into variables. When you use FetchXML Builder, you will see rather quickly that the results are returned as XML so it makes sense to use the XmlDocument class to manipulate this data. So start by placing a "using System.Xml;" clause at the top of your C# file and modify the code below to fit your needs.
string result = service.Fetch(fetchXML);
string attributevalue;
XmlDocument doc = new XmlDocument();
doc.LoadXml(result);
foreach(XmlNode node in doc.DocumentElement.ChildNodes)
attributevalue = node.SelectSingleNode("mycrmattribute").InnerText;
dynamic-ax.co.uk: Import Emails from Outlook 2007 into Dynamics AX 2009 Blog bot DAX Blogs 1 03.07.2009 07:17
Jim Wang: Get Entity/Attribute's Display Name from CRM database Blog bot Dynamics CRM: Blogs 0 28.03.2009 01:05
Jim Wang: CRM 4.0 Get attribute value from entity's GUID using JScript Blog bot Dynamics CRM: Blogs 0 11.02.2009 06:05
Часовой пояс GMT +3, время: 18:13.
