Старый 08.11.2009, 11:58   #3
Alpen is offline
Alpen
Сообщение от slivka_83 Посмотреть сообщение
Подробные ошибки включены? http://mmcrm.ru/?p=137
Для лога http://mmcrm.ru/?p=751
1 error при сохранении возможной сделки
at InProcessCrmService.Execute(Object request)
at PlatformCommand.ExecuteInternal()
at UpdateCommand.Execute()
at EntityProxy.Update(Boolean performDuplicateCheck)
at AppForm.SaveEntity(EntityProxy entity, FormEventId eventType, String redirectPath, Boolean performDuplicateCheck)
at AppForm.RaiseDataEvent(FormEventId eventId)
at EndUserForm.Initialize(Entity entity)
at CustomizableForm.Execute(Entity entity, String formType)
at CustomizableForm.Execute(Entity entity)
at OpportunityDetailPage.ConfigureForm()
at AppUIPage.OnPreRender(EventArgs e)
at Control.PreRenderRecursiveInternal()
at Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at Page.ProcessRequest()
at Page.ProcessRequestWithNoAssert(HttpContext context)
at Page.ProcessRequest(HttpContext context)
at maksoft_sfa_opps_edit_aspx.ProcessRequest(HttpContext context)
at CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
at ApplicationStepManager.ResumeSteps(Exception error)
at HttpApplication.System.Web.IHttpAsyncHandler.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object extraData)
at HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr)
at HttpRuntime.ProcessRequestNoDemand(HttpWorkerRequest wr)
at ISAPIRuntime.ProcessRequest(IntPtr ecb, Int32 iWRType)
>non-plugin non- CrmException detected - report will be sent to Watson:
System.ArgumentException: Путь имеет недопустимую форму.
в System.IO.Path.NormalizePathFast(String path, Boolean fullCheck)
в System.IO.Path.NormalizePath(String path, Boolean fullCheck)
в System.IO.Path.GetFullPathInternal(String path)
в System.IO.FileInfo..ctor(String fileName)
в Microsoft.Crm.Extensibility.PluginAssemblyFactory.IsFileNameOnly(String fileName)
в Microsoft.Crm.Extensibility.PluginAssemblyFactory.LoadAssembly(String assemblyFile)
в Microsoft.Crm.Extensibility.PluginAssemblyFactory.CreateInstance(Guid pluginAssemblyId, IOrganizationContext context)
в Microsoft.Crm.Caching.PluginAssemblyCacheLoader.LoadCacheData(Guid key, IOrganizationContext context)
в Microsoft.Crm.Caching.CrmMultiOrgCache`2.CreateEntry(TKey key, IOrganizationContext context)
в Microsoft.Crm.Caching.CrmSharedMultiOrgCache`2.LookupEntry(TKey key, IOrganizationContext context)
в Microsoft.Crm.Caching.PluginTypeCacheLoader.LoadCacheData(Guid key, IOrganizationContext context)
в Microsoft.Crm.Caching.PluginTypeCache.LookupEntry(Guid pluginTypeId, IOrganizationContext context)
в Microsoft.Crm.Extensibility.PluginStep..ctor(Guid stepId, StepDescriptionCache stepDescriptionCache, SecureConfigurationCache stepSecureConfigurationCache, StepImageDescriptionCache stepImageDescriptionCache, CrmEventLog eventLog, IOrganizationContext context)
в Microsoft.Crm.Extensibility.PipelineStepFactory.CreateInstance(Guid stepId, IOrganizationContext context)
в Microsoft.Crm.Caching.PipelineStepCacheLoader.LoadCacheData(Guid key, ExecutionContext context)
в Microsoft.Crm.Caching.ObjectModelCacheLoader`2.LoadCacheData(TKey key, IOrganizationContext context)
в Microsoft.Crm.Extensibility.ImageRetrievalStep.MergeEntityRequests(PipelineExecutionContext context, Dictionary`2 entityRequests)
в Microsoft.Crm.Extensibility.ImageRetrievalStep.Execute(PipelineExecutionContext context)
в Microsoft.Crm.Extensibility.Pipeline.Execute(PipelineExecutionContext context)
в Microsoft.Crm.Extensibility.MessageProcessor.Execute(PipelineExecutionContext context)
в Microsoft.Crm.Extensibility.InternalMessageDispatcher.Execute(PipelineExecutionContext context)
в Microsoft.Crm.Extensibility.ExternalMessageDispatcher.Execute(String messageName, Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, PropertyBag fields, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
в Microsoft.Crm.Sdk.RequestBase.Process(Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
в Microsoft.Crm.Sdk.RequestBase.Process(CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
в Microsoft.Crm.Sdk.CrmServiceInternal.Execute(RequestBase request, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
в Microsoft.Crm.Sdk.InProcessCrmService.Execute(Object request)
2 error
at ErrorInformation.LogError()
at ErrorInformation..ctor(Exception exception, Uri requestUrl, Boolean logError)
at ErrorInformation..ctor(Exception exception, Uri requestUrl)
at AppForm.HandleSaveEntityException(Exception exception, FormEventId eventType, String url)
>MSCRM Error Report:
Error: Путь имеет недопустимую форму.
Error Message: Путь имеет недопустимую форму.
Source File: Not available
Line Number: Not available
Request URL: http://server/Maksoft/sfa/opps/edit.aspx?id={38F47E30-B9AD-DE11-9360-00A0C9C7B6A3}
Stack Trace Info: [ArgumentException: Путь имеет недопустимую форму.]
в Microsoft.Crm.Application.Platform.ServiceCommands.PlatformCommand.ExecuteInternal()
в Microsoft.Crm.Application.Platform.ServiceCommands.UpdateCommand.Execute()
в Microsoft.Crm.Application.Platform.EntityProxy.Update(Boolean performDuplicateCheck)
в Microsoft.Crm.Application.Forms.AppForm.SaveEntity(EntityProxy entity, FormEventId eventType, String redirectPath, Boolean performDuplicateCheck)
Непонятно
При слиянии записей-дубликатов выскакивает ошибка о "циклической ссылке" Bakai Madybaev Dynamics CRM: Функционал 11 20.12.2011 22:59
Модуль "Маркетинг" - ОШИБКА с действиями кампаний nataly_veksler Dynamics CRM: Разработка 5 06.11.2009 00:48
Как отследить создание предложения из возможной сделки ZooY Dynamics CRM: Разработка 2 28.11.2008 21:00
Ошибка в отчете "Каналы продаж" после изменения процесса продаж Артем Enot Грунин Dynamics CRM: Разработка 2 25.09.2007 09:59
Ошибка "Trust for Delegation" pkost Dynamics CRM: Администрирование 1 03.04.2007 11:07
Часовой пояс GMT +3, время: 04:53.
