Старый 20.11.2009, 09:54   #11
S.Kuskov is offline
S.Kuskov
3,444 / 1781 (66) ++++++++
Мои результаты
static void JobTestSpeed(Args _args)
    int i;
    void t1()
        RContractTable RContractTable;
        int       start;
        int       end;
        start = timenow();
        while select * from RContractTable {}
        end = timenow();
        info("while " + time2str(end-start,1,1));
    void t2()
        int       start;
        int       end;
        QueryRun  queryRun;
        query     query;
        start = timenow();
        query = new Query();
        query.addDataSource(tablenum(RContractTable));
        queryRun = new QueryRun(query);
        while (queryRun.next())
            RContractTable = queryRun.get(TableNum(RContractTable));
        end = timenow();
        info("queryRun " + time2str(end-start,1,1));
    info(int642str((select count(RecId) from RContractTable).RecId));
    for (i = 1; i <= 5; i++) t1();
    for (i = 1; i <= 5; i++) t2();
    for (i = 1; i <= 5; i++) {t1();t2();}
21291
while 00:00:35
while 00:00:32
while 00:00:36
while 00:00:36
while 00:00:33
queryRun 00:00:36
queryRun 00:00:35
queryRun 00:00:38
queryRun 00:00:37
queryRun 00:00:40
while 00:00:36
queryRun 00:00:38
while 00:00:37
queryRun 00:00:35
while 00:00:36
queryRun 00:00:34
while 00:00:32
queryRun 00:00:34
while 00:00:34
queryRun 00:00:34
Тестировал на живой базе. Так-что разброс есть, но в обе стороны и не 50%
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 04.05.2009 14:05
palleagermark: Sample union query from AX 2009 Blog bot DAX Blogs 0 11.07.2008 20:05
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 28.10.2006 16:40
Помогите новичку в создании Query lev DAX: Программирование 2 19.06.2006 10:29
Помогите с query 6apcyk DAX: Программирование 23 09.09.2005 13:50
Часовой пояс GMT +3, время: 08:36.
