Старый 24.11.2009, 12:38   #15
Soulcar is offline
Soulcar
Аватар для Soulcar
129 / 10 (1) +
Может всетаки ролапчик накатите?
На что именно, connector я переустанавливал с разрешением загрузки обновлений...
Может это поможет:
Request URL:
Ссылкаhttp://ХХХХХХХХХХХХХ/CRMReports/AdHocWizard/SuccessFailurePage.aspx?id=&CRMWRPCToken=I65pVM3aEd6dGgAVXQAGEZ+U6aKFD8eaJf3wsUPSmQ4pbEnjS1X9cfKQMD2yXQNd&CRMWRPCTokenTimeStamp=633946522495619986[/url]
Microsoft CRM Unhandled Error Details:
Server Error in '/' Application.
The request failed with HTTP status 400: Bad Request.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Net.WebException: The request failed with HTTP status 400: Bad Request.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[WebException: The request failed with HTTP status 400: Bad Request.]
System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) +2529
System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) +275
Microsoft.Crm.ReportingServices2005.ReportingService2005.CreateReport(String Report, String Parent, Boolean Overwrite, Byte[] Definition, Property[] Properties) +191
Microsoft.Crm.Reporting.ReportServer.UploadReport(String path, Byte[] reportDefinition, String name, String description) +390
[CrmReportingException: The request failed with HTTP status 400: Bad Request.]
Microsoft.Crm.Reporting.ReportServer.UploadReport(String path, Byte[] reportDefinition, String name, String description) +535
Microsoft.Crm.Reporting.ReportServer.UploadReport(SRSReport report, String reportId, String name, String description) +84
Microsoft.Crm.ObjectModel.ReportService.UploadSRSReport(Guid id, String name, String description, SRSReport srsReport, ExecutionContext context) +300
Microsoft.Crm.ObjectModel.ReportService.CreateInternal(IBusinessEntity entity, Boolean isScheduledReport, ExecutionContext context) +1891
Microsoft.Crm.ObjectModel.ReportService.CreateFromTemplate(String wizardXml, ExecutionContext context) +223
[TargetInvocationException: Exception has been thrown by the target of an invocation.]
System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) +0
System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) +1255
System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +38
System.Web.Services.Protocols.LogicalMethodInfo.Invoke(Object target, Object[] values) +211
Microsoft.Crm.Extensibility.InternalOperationPlugin.Execute(IPluginExecutionContext context) +160
Microsoft.Crm.Extensibility.PluginStep.Execute(PipelineExecutionContext context) +575
Microsoft.Crm.Extensibility.Pipeline.Execute(PipelineExecutionContext context) +474
Microsoft.Crm.Extensibility.MessageProcessor.Execute(PipelineExecutionContext context) +1859
Microsoft.Crm.Extensibility.InternalMessageDispatcher.Execute(PipelineExecutionContext context) +349
Microsoft.Crm.Extensibility.ExternalMessageDispatcher.Execute(String messageName, Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, PropertyBag fields, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) +1427
Microsoft.Crm.Sdk.RequestBase.Process(Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) +149
Microsoft.Crm.Sdk.RequestBase.Process(CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) +183
Microsoft.Crm.Sdk.CrmServiceInternal.Execute(RequestBase request, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId) +465
Microsoft.Crm.Sdk.InProcessCrmService.Execute(Object request) +2352
Microsoft.Crm.Application.Platform.ServiceCommands.PlatformCommand.ExecuteInternal() +957
Microsoft.Crm.Application.Platform.DataSource.CreateFromTemplate(String wizardXml) +50
Microsoft.Crm.Web.Reporting.AdHocWizard.SuccessFailurePage.ConfigurePage() +197
Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e) +28
System.Web.UI.Control.PreRenderRecursiveInternal() +147
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3548
Basic Server & Client Information:
What the End User would have seen:
Последний раз редактировалось Soulcar; 24.11.2009 в 12:43.
Рассылка отчетов по электронной почте zhenek Dynamics CRM: Функционал 11 11.09.2009 10:07
Сбой при запуске отчетов с сервера CRM xmarina Dynamics CRM: Администрирование 5 03.09.2009 14:46
Ошибка при создании отчётов! moskalevas Dynamics CRM: Функционал 13 23.07.2009 14:14
Проблема с публикацией отчетов - не работает "Сделать отчет доступным для организации" serjio72 Dynamics CRM: Администрирование 8 16.07.2009 18:11
Не работает модуль отчетов Maxoon Dynamics CRM: Администрирование 25 03.03.2009 12:53
Часовой пояс GMT +3, время: 14:49.
