Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 25.11.2009, 22:32   #1
Kent is offline
Kent
ax 2009 workflow approvals
Hi,
I have workflow template with two Approvals. Example, SalesApproval(first step) and PurchApproval (second step).
Template property CompleatedEventHandler has class with method, example "Compleate" where I can update my ApprovalStatus or something else. How can I known, which Approval (SalesApproval or PurchApproval) called this method?
Or should I create separate classes for each Approval and set this classes for needed Outcomes (Approve, Deny,etc.)
Thanks.
Старый 26.11.2009, 20:10   #2
Mykola Galak is offline
Mykola Galak
Сообщение от Kent Посмотреть сообщение
Hi,
Thanks.
Method Completed of the class specified in CompletedEventHandler property called when all activities associated with the template are done.
If you want to track Approval completion event you need to implement WorkflowElementCompletedEventHandler interface and specify its name in EventHandler property of Approval outcome. Two separate classes for each Approval needs to be implemented.
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Arijit Basu: AX 2009 Workflows: A Quick overview Blog bot DAX Blogs 0 19.06.2008 02:07
Часовой пояс GMT +3, время: 15:45.
