Старый 15.02.2010, 11:30   #3
Tarasov E is offline
Tarasov E
Аватар для Tarasov E
100 / 11 (1) +
Асинхронный сервис не останавливается.
С прикреплением файлов у меня пока проблемы - выкладываю полный лог так:
Код:
# CRM Tracing Version 2.0
# LocalTime: 2010-02-15 04:07:22.5
# Categories:
# CallStackOn: No
# ComputerName: VMS2
# CRMVersion: 4.0.7333.1644
# DeploymentType: OnPremise
# ScaleGroup:
# ServerRole: AppServer, AsyncService, DiscoveryService, WebService, ApiServer, HelpServer, DeploymentService
[2010-02-15 04:07:22.5] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    8 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {1F665E73-CE19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
   at Microsoft.Crm.Workflow.Activities.StopWorkflowActivity.Execute(ActivityExecutionContext executionContext)
   at System.Workflow.ComponentModel.ActivityExecutor`1.Execute(T activity, ActivityExecutionContext executionContext)
   at System.Workflow.ComponentModel.ActivityExecutor`1.Execute(Activity activity, ActivityExecutionContext executionContext)
   at System.Workflow.ComponentModel.ActivityExecutorOperation.Run(IWorkflowCoreRuntime workflowCoreRuntime)
   at System.Workflow.Runtime.Scheduler.Run()
[2010-02-15 04:54:30.2] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    8 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {CDCD400A-D519-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 04:54:48.7] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   17(MSCRM:-TimerProcessor.ExecuteTimers) |Category: Platform.Async |User: 00000000-0000-0000-0000-000000000000 |Level: Error | DataAccessBase.ExecuteSqlCommandAndProcessRecords
>VMS2.MSCRMAsyncService.ccac1a49-9e2d-45f7-8695-d3f6024b4849: Exception while trying to execute query: update AsyncOperationBase
set
	HostId = 'VMS2.MSCRMAsyncService.ccac1a49-9e2d-45f7-8695-d3f6024b4849',
	StateCode = 2,
	StatusCode = 20,
	StartedOn = DATEADD(MILLISECOND, -1*DATEPART(MILLISECOND, GETUTCDATE()), GETUTCDATE()),
	ModifiedOn = DATEADD(MILLISECOND, -1*DATEPART(MILLISECOND, GETUTCDATE()), GETUTCDATE()),
	ModifiedBy = CreatedBy,
	RetryCount = case coalesce(ErrorCode, 0)
					when 0 then coalesce(RetryCount, 0)
					else coalesce(RetryCount, 0)+1
					end
output
	INSERTED.AsyncOperationId,
	INSERTED.OperationType,
	INSERTED.Data,
	INSERTED.DependencyToken,
	INSERTED.RegardingObjectId,
	INSERTED.RegardingObjectIdName,
	INSERTED.RegardingObjectIdDsc,
	INSERTED.RegardingObjectTypeCode,
	INSERTED.OwningUser,
	INSERTED.RetryCount,
	INSERTED.RecurrencePattern,
	INSERTED.RecurrenceStartTime,
	INSERTED.CorrelationId,
	INSERTED.CorrelationUpdatedTime,
	INSERTED.Depth,
	INSERTED.PrimaryEntityType,
	INSERTED.RequestId
where
	StateCode = 0
and DeletionStateCode = 0
and	AsyncOperationId in
	(select top(1999) AsyncOperationId from AsyncOperationBase where StateCode = 0 and DeletionStateCode = 0 order by Sequence asc) - System.Data.SqlClient.SqlException: Transaction (Process ID 83) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
   at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
   at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
   at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
   at System.Data.SqlClient.SqlDataReader.HasMoreRows()
   at System.Data.SqlClient.SqlDataReader.ReadInternal(Boolean setTimeout)
   at Microsoft.Crm.Asynchronous.DataAccessBase.ExecuteSqlCommandAndProcessRecords(IDbCommand command, RecordProcessor recordProcessor)
[2010-02-15 04:54:48.8] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   17(MSCRM:-TimerProcessor.ExecuteTimers) |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | AsyncEventLogHelper.LogOrganizationFailure
>Received SQL Exception accessing organization {E26D7E2D-33B0-417E-8875-7E0C045FDA3E}. Exception: System.Data.SqlClient.SqlException: Transaction (Process ID 83) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
   at Microsoft.Crm.Asynchronous.QueueDataAccess.SelectEvents(Int32 numberOfEvents)
[2010-02-15 07:29:04.2] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {5C886BA2-EA19-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 08:26:40.9] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {0D020DAE-F219-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 08:43:38.6] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {20665E73-CE19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 08:44:12.4] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {BAFC1822-F519-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 08:55:24.2] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {FBB6D176-F619-DF11-A3DC-16C03228C478} - System.Net.WebException: The operation has timed out
   at System.Web.Services.Protocols.WebClientProtocol.GetWebResponse(WebRequest request)
   at System.Web.Services.Protocols.HttpWebClientProtocol.GetWebResponse(WebRequest request)
   at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
   at E_mailFromQuote1.ksdb3.ReportExecutionService.LoadReport(String Report, String HistoryID)
   at E_mailFromQuote1.SendReport.Execute(ActivityExecutionContext executionContext)
   at System.Workflow.ComponentModel.CompositeActivityExecutor`1.Execute(T activity, ActivityExecutionContext executionContext)
[2010-02-15 09:00:05.1] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {55E05A5A-F719-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:09:32.0] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {42CF38A8-F819-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:11:22.6] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {0D597F3C-F819-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:12:27.8] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   20 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {56E05A5A-F719-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:12:57.8] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {B9FC1822-F519-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:15:58.0] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {F3DB3392-F919-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:20:49.4] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   20 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {B5228D20-BE19-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:32:51.3] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {A65A05F0-FB19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:35:06.6] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {C27F7F40-FC19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:40:23.0] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {5FCD4EA8-7A18-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:41:18.7] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {C37F7F40-FC19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:45:43.6] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {61C738BA-FD19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:47:50.0] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {62C738BA-FD19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:50:54.9] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {54F9093D-FE19-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:56:55.7] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {A1665E4B-FF19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:58:06.4] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {A2665E4B-FF19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 09:59:51.3] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {FB7297B4-FF19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:02:51.8] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {8794891F-001A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:07:17.9] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   20 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {C02F6ABE-001A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:07:27.5] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   20 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {C9C870C4-001A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:11:53.6] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {CA360162-011A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:29:01.9] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {622F34C3-031A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
# LocalTime: 2010-02-15 10:32:37.8
# Categories:
# CallStackOn: No
# ScaleGroup:
[2010-02-15 10:32:37.8] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    8 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {90B45F1B-041A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:35:36.5] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   15 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {C8306474-041A-DF11-A3DC-16C03228C478} - System.Net.WebException: The operation has timed out
[2010-02-15 10:36:00.7] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   12 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {552F0FC1-041A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:36:31.0] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   13 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {D14553D5-041A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:38:52.3] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   13 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {76EBAF26-051A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
# LocalTime: 2010-02-15 10:43:19.8
# Categories:
# CallStackOn: No
# ScaleGroup:
[2010-02-15 10:43:19.8] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   15 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {5D33A9BC-051A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:45:17.8] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   20 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {16EE9460-FB19-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:45:42.9] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   20 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {A75A05F0-FB19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:46:17.6] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {0ECBDC22-FC19-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:50:43.5] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    3 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {DFA55BAE-041A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 10:55:24.3] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   20 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {C12F6ABE-001A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 11:00:15.2] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   20 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {93E237E7-071A-DF11-A3DC-16C03228C478} - System.Net.WebException: The operation has timed out
# LocalTime: 2010-02-15 11:07:32.7
# Categories:
# CallStackOn: No
# ScaleGroup:
[2010-02-15 11:07:32.7] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   22 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {562F0FC1-041A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 11:13:04.9] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {77EBAF26-051A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 11:14:38.2] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {BF4CB4A7-FE19-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 11:14:58.2] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {E63ECDCA-FF19-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 11:15:58.3] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   22 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {2EF320CD-071A-DF11-B1A4-003048743D05} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 11:19:56.2] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   21 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {E20D00E6-0A1A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
[2010-02-15 11:21:20.7] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:    4 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {0CE58818-0B1A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
# LocalTime: 2010-02-15 11:27:39.0
# Categories:
# CallStackOn: No
# ScaleGroup:
[2010-02-15 11:27:39.0] Process:CrmAsyncService |Organization:e26d7e2d-33b0-417e-8875-7e0c045fda3e |Thread:   19 |Category: Platform.Workflow |User: 00000000-0000-0000-0000-000000000000 |Level: Error | WorkflowHost.OnWorkflowTerminated
>Workflow terminated: {685568E6-0B1A-DF11-A3DC-16C03228C478} - Microsoft.Crm.Workflow.Activities.StopWorkflowException
Бизнес-процесс был запущен в 11:27
Отправка ярлыка задачи с помощью бизнес-процесса. DImaNec Dynamics CRM: Разработка 6 06.06.2009 13:42
Ошибка при публикации бизнес-процесса Верба Dynamics CRM: Администрирование 2 27.03.2009 16:18
Событие "Назначение записи" для бизнес-процесса Lazarus Dynamics CRM: Функционал 1 22.01.2009 19:54
Мир CRM: Отправка ярлыка по электронной почте при помощи бизнес-процесса Blog bot Dynamics CRM: Blogs 0 29.09.2008 07:16
Мир CRM: Автоматизирование добавления основного контакта при помощи Бизнес-Процесса Blog bot Dynamics CRM: Blogs 0 31.07.2008 02:08
Часовой пояс GMT +3, время: 14:09.
