Старый 24.05.2010, 15:05   #1
25,643 / 848 (80) +++++++
saveenr: Dynamics AX and SSRS Learning Roadmap - Part 6 - Improving the SandBox - Separating Code in a Referenced Assembly
Источник: http://blogs.msdn.com/saveenr/archiv...-assembly.aspx
Up till now I’ve put all the C# code in the same project as the report definitions. So far this hasn’t posed any special problems, but as we move forward and write more code we will see that there are benefits to keeping the C# code in a separate assembly entirely.
Benefits:
  • Allows us to update the reports without touching the code. This is useful if you have a larger team – where one developer owns the “data” and another one creates the reports.
  • If you need to share code between multiple reports, this is an ideal way of putting it into a central location.
  • Once we finally start integrating AX with SSRS, this technique will become very important – AX reporting with SSRS uses this extensively.
http://vimeo.com/11623847
paruvella: Dynamics Ax - Simple SSRS report example by using Ax-Query and Ranges Blog bot DAX Blogs 0 08.01.2010 16:05
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Dynamics AX: Dynamics AX - Why it's good: Value point two, "The Stack" Blog bot DAX Blogs 1 13.11.2008 13:30
jinx: SSRS Berichtsviewer Erweiterung f?r Dynamics AX 4.0 - Version 0.1 Blog bot DAX auf Deutsch 6 10.08.2007 12:54
Часовой пояс GMT +3, время: 04:05.
