paruvella: De-serialization of string format XML in Dynamics Ax
Источник: http://paruvella.spaces.live.com/Blo...4DB0!546.entry
============== For some requirements, we need to store XML as a string in some Ax-Tables and need to de-serialize this string field as a document at a later point of time. During de-serialization process need to store the XML values in to some tables. The following example will illustrate, how XML string can be read using X++ code. static void PSReadXMLFileAsString(Args _args) { XmlTextReader xmlTextReader ; str xmlString = '' +'' +'o130006' +'260005' +'' +''; ; xmlTextReader = XmlTextReader::newXml(xmlString, true) ; xmlTextReader.read() ; while(xmlTextReader.read()) { switch (xmlTextReader.NodeType()) { case XmlNodeType::Element: // The node is an element. print (""); break; case XmlNodeType::Text: //Display the text in each element. print (xmlTextReader.Value()); break; case XmlNodeType::EndElement: //Display the end of the element. print (""); break; } } pause; } ![]() Источник: http://paruvella.spaces.live.com/Blo...4DB0!546.entry
