Старый 22.09.2010, 23:05   #1
25,644 / 848 (80) +++++++
East Ocean - Technical: Configuration registry key is invalid
Источник: http://eastoceantechnical.blogspot.c...s-invalid.html
I get error message from one of the server "The Configuration Registry key is invalid"
Google around looks like the server's performance counter in the registry, which has been corrupted and needs to be restored.
To resolve this, rebuild the performance counter library by using the follow command:
C:\WINDOWS\system32> lodctr /R
East Ocean - Technical: The path is not of a legal form - Data Migration Manager Blog bot Dynamics CRM: Blogs 0 11.08.2010 11:05
East Ocean - Technical: CRM 4 - Small changes:big effect Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
East Ocean - Technical: Maximum attributes supported by CRM 4! Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 14:20.
