Старый 06.10.2010, 13:05   #1
axhelper: Strange behaviour when calling form
Источник: http://feedproxy.google.com/~r/AxHel...ling-form.html
I was building an extended search form for one of our customers. When called from one form everything worked fine, but when called from a second form my grid only contained one record… Exact same parameters, same menu item etc. When looking around I found that when the error occured, I was calling from a form which had same table (InventTable) as one of it’s main Data Sources. This is one of the non-documented features in AX, if same table exists in the Data Sources in both forms, AX tryes to link them together. To break this connection I had to call ClearDynaLinks() on the second form. Like below, in my search form’s init method.
void init()
InventTable_ds.query().dataSourceTable(
tablenum(InventTable)).clearDynalinks();
paruvella: Form browser for Dynamics Ax-Tables Blog bot DAX Blogs 0 26.06.2010 01:09
Kashperuk Ivan: Lookup form returning more than one value Blog bot DAX Blogs 0 29.01.2010 18:05
casperkamal: Preventing a form getting added to "LastActivated Form" in Dynamics Ax Blog bot DAX Blogs 1 27.08.2007 23:17
Axapta Lessons: Trapping keystrokes in a Form Blog bot DAX Blogs 13 01.11.2006 18:16
Часовой пояс GMT +3, время: 21:15.
