Старый 09.11.2010, 10:12   #5
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Да действительно
Код:
Property(S): DIR_VS_ENVIRONMENT = D:\
Property(S): TARGETDIR = D:\
Property(S): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(S): Dir_LocalUserApplicationDataMSDAX = C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics Ax\
Property(S): Dir_LocalUserApplicationDataMicrosoft = C:\Documents and Settings\All Users\Application Data\Microsoft\
Property(S): Dir_UserDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(S): DirGAC_x86 = D:\globalassemblycache\GAC32\
Property(S): DirGAC = D:\globalassemblycache\
Property(S): DIR_Client_Common = C:\Program Files\Microsoft Dynamics AX\Common\
Property(S): DIR_MicrosoftDynamicsAX = C:\Program Files\Microsoft Dynamics AX\
Property(S): ProgramMenuFolder = C:\Documents and Settings\All Users\Главное меню\Программы\
Property(S): ReportingDir = C:\Program Files\Microsoft Dynamics AX\50\Reporting Services\
Property(S): DIR_WSS = C:\Program Files\Microsoft Dynamics AX\50\WSS\
Property(S): ProgramFilesFolder = C:\Program Files\
Property(S): DIR_Client = C:\Program Files\Microsoft Dynamics AX\50\Client\
Property(S): INSTALLDIR32 = C:\Program Files\Microsoft Dynamics AX\50\
Property(S): DIR_MicrosoftDynamicsAX32 = D:\Program Files\Microsoft Dynamics AX\
Property(S): ProgramFilesFolder32 = D:\Program Files\
Setup parameters (http://technet.microsoft.com/en-us/l.../aa548130.aspx)
InstallPath %ProgramFiles%\Microsoft Dynamics AX\50
Indicates the root path for all Microsoft Dynamics AX files installed on a computer.
InstallPath32Bit %ProgramFiles%\Microsoft Dynamics AX\50
Indicates the root path for all 32-bit Microsoft Dynamics AX files installed on a computer. This parameter is used only when installing on a 64-bit operating system.
client, installation
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Dynamics AX: SoftEnigma: ARP 2.0 for Dynamics AX 2009 (Launched) Blog bot DAX Blogs 0 26.06.2008 21:06
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Часовой пояс GMT +3, время: 10:09.
